727 Trans problems #444568
08/20/09 09:26 PM
08/20/09 09:26 PM
Tecumseh, Ontario, Canada
Moparnut Offline OP
Moparnut  Offline OP
A buddy of mine came over in his 70 Cuda. 383.
Trans is a 727.
When car is put into gear it goes in hard with a mild bang.
Car run in 1st gear good but does not want to shift into 2nd unless you get on it then release the gas. Same with 3rd.
Is this an adjustment problem or is the trans on its way out.
Any suggestions would be appreciated.
Re: 727 Trans problems [Re: Moparnut] #444569
08/20/09 10:30 PM
08/20/09 10:30 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
had a simlar problem with my old dodge truck.. the housing was wore so bad inside the case that the drum would rock in the case... it need to be disassemble for inspection just in case..
Re: 727 Trans problems [Re: Moparnut] #444570
08/20/09 10:44 PM
08/20/09 10:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Check the throttle pressure (kickdown)linkage at carb for correct adjustment.
Re: 727 Trans problems [Re: buildanother] #444571
08/21/09 01:24 AM
08/21/09 01:24 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Check to see the linkage is pulled forward with a spring on the Throttle shaft of the carb.
