Dana ID. Take chunk, or all?
#444335
08/20/09 04:00 PM
08/20/09 04:00 PM
Posts: 2,886 US of A
A38s!
US of A
Going to check out this in a 64 d100 shorty on Sat. Not orig.
It's a locker. Waiting for info off the cover, but you know how that goes...
He says $75 if I pull it. This is the only pic I was sent. Can anyone ID which one it is? Would you take it all, or ?
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Dana ID. Take chunk, or all?
[Re: A38s!]
#444336
08/20/09 05:49 PM
08/20/09 05:49 PM
Posts: 4,753 Florida
BDW
[Re: A38s!]
#444338
08/20/09 06:21 PM
08/20/09 06:21 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
I wouldn't nickle-and-dime it. Take it ALL for $110. I paid $73 in 2001 for a Dana 60, 4:10 Gears, Sure-Grip, out of a Dodge B200 Van (semi-Floating Axle, drum-to-drum) at a Pick-A-Part. Had to have Car-Type bearing ends grafted on to the axle-tubes, added "Green-Bearings," "Strange Eng" axles; It's been under the rear of my '71 Charger ever since. Here is the Dana Corporation Rear End ID Decoder, Known as the "Bill of Material Number" stamped ON the unit: Dana Corp Bill of Material Rear End ID number Decoder Dana 60 Maint ManualDana 60 Vehicle Usage List
[Re: A38s!]
#444342
08/21/09 04:57 AM
08/21/09 04:57 AM
D_C
Yes, the "HD" version IS heavier (weight) than the "Standard" version Dana 60 housing, but not all that much heavier.
Also, depends on what application is planed for, such as swapping it into a truck.
Even a heavier street-strip car. Weight is the enemy, but unless this is a very serious race machine, you can likely reduce weight elsewhere or just accept it.
[Re: Mr_fixit]
#444345
09/09/09 01:27 PM
09/09/09 01:27 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
That's a dana 60 hd.
How do you ID the HD from that picture? I'm looking for a Dana 60 and don't really want to end up with a HD....how do I tell the difference?
