Page 11 of 12 < 1 2 9 10 11 12 >
#44548 - 01/31/13 08:27 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Mr.Yuck]
Thumperdart Offline
Loc: State of confusion
one more for the haters...
I`m not a cowl hater but just think some Mopars don`t look right and as I stated before about your scoop..........I don`t think you`re drawing in much air........
#44549 - 01/31/13 08:42 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Thumperdart]
Mr.Yuck Offline
Loc: Brookeville, Md
not for air, it's for clearance.
#44550 - 01/31/13 08:44 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Mr.Yuck]
Dont you run a six pack? Clearance for a factory option that fits under a flat hood?
#44551 - 01/31/13 09:01 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Mr.Yuck]
Thumperdart Offline
Where do you draw air from?
#44552 - 01/31/13 09:19 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: ]
Mr.Yuck Offline
not w/ stage VI heads and 1/2" Meth/H2O plates....
#44553 - 01/31/13 09:22 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Thumperdart]
Mr.Yuck Offline
I guess from the cowl and from what ever runs thru the engine bay. The cowl does get some air as I can see it lift durning a pass, so much so I had add an extra pin. It's maybe 4" from the windshield.
#44554 - 01/31/13 09:39 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Mr.Yuck]
1000+sbm Offline
My little cowl.
#44555 - 01/31/13 09:50 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 1000+sbm]
mikeysmopars Offline
Loc: fresno ca
One i painted for a buddy
Founder and CEO of the Central Valley Mopar Drag Pack
#44556 - 01/31/13 11:44 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: mikeysmopars]
6PKRTSE Offline
Loc: Motor City
Alot of nice looking cars here. I think they look best on the E-Bodies as mentioned above since they are similar to looks of a 1ST Gen Camaro but I just can't bring myself to put one on any of my cars. Still undecided what scoop I am going to run on my Challenger.
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, Big Inch Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner.
1996 2500 RAM 488 V-10 4X4.
2012 Challenger R/T Classic.
#44557 - 01/31/13 11:48 AM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 6PKRTSE]
Loc: fresno ca
T/A Hood on a challenger is the coolest, If you need more clearance, Cut & Raise it, I have seen the extended version of the T/A hood. Anyone here got one?
#44558 - 01/31/13 12:25 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: mikeysmopars]
Jeepmon Offline
Loc: Sunnyvale, CA
I got the cowl hood simply because I couldnt find a forward facing scoop that I liked.. everything that would fit and provide enough clearance, looked like a beached whale sitting on the hood..
Before...
After...
No Hood...
You tell me which one looks better!!
73 Duster 360 stroker
http://www.cardomain.com/ride/2594657
#44559 - 01/31/13 01:26 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Jeepmon]
1000+sbm Offline
i like the cowl on your car!
#44560 - 01/31/13 01:29 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Jeepmon]
Dbl"00"Joe Offline
Loc: N.W. Indiana
The cowl looks better for sure! Six pack and Hemi scoops shouldnt be on every mopar built...
#44561 - 01/31/13 01:39 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Dbl"00"Joe]
1000+sbm Offline
I agree
#44562 - 01/31/13 01:42 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: Dbl"00"Joe]
SG duster Offline
Loc: Hinterland SE Qld Aust
same goes for cowl scoops, some look good some dont. it realy is the preference of the owner
#44563 - 01/31/13 01:47 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: SG duster]
CHAPPER Offline
Loc: Belpre,Ohio
It's all about air and air turbulence in the carb area. I have a 6pak hood/scoop and the cowl hood/scoop. I have never gotten my 6 pak set-up to make one good, clean pass.
If you like drag racing, support your local track.
#44564 - 01/31/13 01:48 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: CHAPPER]
CHAPPER Offline
Loc: Belpre,Ohio
So I run this,,
#44565 - 01/31/13 03:03 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: CHAPPER]
67HEMI Offline
Loc: Mopar Lane,Mississippi
This is my forward facing scoop I hope to use in a month or so!
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
#44566 - 01/31/13 03:55 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 67HEMI]
dogdays Offline
If ya gotta run a '69 Camaro cowl hood, just get a '69 camaro!
Grumpy
#44567 - 01/31/13 04:16 PM Re: Cowl Hood Scoops.. Why on a MOPAR????? [Re: 67HEMI]
b1dartsport Offline
Loc: western pennsylvania
Here is the 4.5" twin snorkel that I got from AAR fiberglass. It is 2" taller than the stock snorkel that came on my car. I got it to use on the street because it clears the Indy intake and is about the most stock looking one that does so. I might try it on the track, but I also have a pin on light weight cowl hood for racing.
25,697 Registered Members
196,732 Topics
Thermostats designs that “fail open” experiences?
by 360view
01/19/19 09:01 AM
Anyone from Livingston N. J. ?
by blewbyu
01/19/19 08:31 AM
Are cassettes making a comeback?
by DUFFMAN
01/18/19 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
01/18/19 10:31 PM
