2004 dakota fan/defrost switch #443417
08/19/09 09:31 PM
08/19/09 09:31 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
in the dashboard.i need to replace it.i am not getting power to the blower.the power port is dead belowe it also. can some1 help me get it out?
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443418
08/19/09 11:53 PM
08/19/09 11:53 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Check the blower resistor they go bad all the time. Your blower should have power to it all the time(key on) the resistor supplies the ground to get your different speeds.
Re: 2004 dakota fan/defrost switch [Re: SALEM1912] #443419
08/20/09 09:01 AM
08/20/09 09:01 AM
ELYRIA,OH
ELYRIA,OH
where is that at?
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443420
08/20/09 10:47 AM
08/20/09 10:47 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The resistor is on bottom of hvac housing right above passenger feet area, almost at firewall.
Re: 2004 dakota fan/defrost switch [Re: buildanother] #443421
08/20/09 12:35 PM
08/20/09 12:35 PM
ELYRIA,OH
ELYRIA,OH
Thanks!i will go look.
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443422
08/20/09 01:31 PM
08/20/09 01:31 PM
ELYRIA,OH
ELYRIA,OH
i dont see anything but plastic under there.i will try to fallow the wiring better maybe it will lead to it.
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443423
08/20/09 01:52 PM
08/20/09 01:52 PM
ELYRIA,OH
ELYRIA,OH
i back probed the fan plug blue wire and got 14.5v on both sides of it.it looks like the fan is bad.
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443424
08/20/09 03:18 PM
08/20/09 03:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Replace the resistor.It supplies ground and if its bad it can have 500 volts and not run.That and if the motor is bad it should be replaced anyway because they arent a very sturdy piece.That and they are a lot cheaper than a motor.Rocky
Chrysler Firepower
Re: 2004 dakota fan/defrost switch [Re: therocks] #443425
08/20/09 04:15 PM
08/20/09 04:15 PM
ELYRIA,OH
ELYRIA,OH
i am going to try to jump the grnd from the plug and see if it is the grnd.i should use a fused wire though.i will try to make 1.
there are some heavy storms moving through so i may have to wait even though i am in a carport.
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443426
08/20/09 05:58 PM
08/20/09 05:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The blower motor resistor may be out under the cowl panel under the hood and it is the normal cause of your troubles.
Re: 2004 dakota fan/defrost switch [Re: stumpy] #443427
08/20/09 06:37 PM
08/20/09 06:37 PM
ELYRIA,OH
ELYRIA,OH
i dont see it under the hood.could it be behind the glovebox?
or do you mean up by the windshield?
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443428
08/20/09 07:24 PM
08/20/09 07:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look through the louvers in the cowl. Yes it could be behind the glove box. My book only goes up to 99.
Re: 2004 dakota fan/defrost switch [Re: stumpy] #443429
08/20/09 07:36 PM
08/20/09 07:36 PM
ELYRIA,OH
ELYRIA,OH
Thanks !
i will have to find the torx for the buttons holding the shield in.do i need to remove the wipers?
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443430
08/20/09 09:08 PM
08/20/09 09:08 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
It is inside under glove box. you will have 12v at both wires to the motor if your resister is bad. As I said before the motor has 12v w/key on all the time the resister supply's the ground for the different speeds.Just buy one from the dealer and look under the pass side dash for the same connector.
Re: 2004 dakota fan/defrost switch [Re: SALEM1912] #443431
08/20/09 10:29 PM
08/20/09 10:29 PM
ELYRIA,OH
ELYRIA,OH
IS THAT IT?i see it right up front.Thanks!!!!
Re: 2004 dakota fan/defrost switch [Re: blownzoom440] #443432
08/21/09 11:20 AM
08/21/09 11:20 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
where is it my 02 dakota?
Re: 2004 dakota fan/defrost switch [Re: 05dakota] #443433
08/21/09 11:38 AM
08/21/09 11:38 AM
chicagoland,usa
chicagoland,usa
Same place above passenger side feet area.
