recurving distributor #443108
08/19/09 05:15 PM
08/19/09 05:15 PM
dark side of the moon
Dougsmopars Offline OP
440 big cam. Likes 19 20 degree's initial advance. Got a recurve kit. Dist is a MP electronic with vac advance. Any suggestions on what the new curve should be? Use or plug the vac advance? Street car. Red light to red light tire frier.
Re: recurving distributor [Re: Dougsmopars] #443109
08/19/09 07:50 PM
08/19/09 07:50 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Depending on the compression the bigger cam will allow more intial timing. I like it all in by 2000-2500.
A locomp 383 with a big cam ran all the inital I gave it. My mild 451 runs 18/18 all in by 2500.
Try it at 37-38 and test and tune it from there at the track.
Re: recurving distributor [Re: Dougsmopars] #443110
08/19/09 08:05 PM
08/19/09 08:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use Eberg's curve from Mopar Action tech. Works great in my street 440.
http://www.moparaction.com/Tech/quest/SLOW_CURVE.html
Tech Question
bob santarsieri, schaumburg, IL, 71 plymouth road runner 440
I have a msd pro billet distributor and msd 6al box. What would be the best setting for the distributor? Right now it is set at 2 heavy silver springs and silver bushing per the instructions. It starts to advance at 1400 and goes to 5500rpm then levels off. What would you suggest. 440ci, 0.040" overbore, 0.474" purple shaft cam, Hedman headers and 3.23 gears. Just street driven. Thanks for your help.
Bob, assuming sufficient octane vs. C.R., you need a curve something close to this:
Under 1400RPM - no advance - set initial at 15 degrees BTDC
2000 - 10 dergees mech (25 total)
2500 - 20 degrees mech (35 total) - all in.
Plus, at LEAST 15 degrees of vacuum advance under light throttle (50 deg. total, 52-55 better).
If it currently doesn't go to full advance until 5500, you're giving up lots of power.
If it currently has less (or no) vacuum advance), you're giving up LOTS of fuel economy and fouling plugs.
Rick
Re: recurving distributor [Re: Lefty] #443111
08/19/09 08:16 PM
08/19/09 08:16 PM
car doesn't like 15 degree's. Get a bad stumble when giving gas. It likes 20 degree's. At 15 best vac i can get at idle in park is 7 inches in gear 3 to 4 inches's. Set at 20 i get close to 11 in park and around 8 in gear.
Re: recurving distributor [Re: Dougsmopars] #443112
08/19/09 08:28 PM
08/19/09 08:28 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Likely a low compression motor that will take all the timing you give it. Whether it matters at the track is another thing.
Re: recurving distributor [Re: GwaiiEagle] #443113
08/19/09 08:46 PM
08/19/09 08:46 PM
It's got 10.5 to 1's in it. Don't care about track. I'm not going racing. Cam is very radical. I didn't build this motor. I wouldn't have gone so radical on cam choise. Previous owner was a racer. Not sure of cam spec's but in the area of 500 lift and 290 advertised duration with a lot of over lap. Really turns on around 4000 rpm. Car had a holley 850 DP mech secondaries. Now has Eddy 800 vac secondaries. Also took the torker II intake off and put a performer intake on. A little more street friendly
Re: recurving distributor [Re: Dougsmopars] #443114
08/19/09 09:02 PM
08/19/09 09:02 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I Don't care about track. I'm not going racing.
I'm not going racing....
Re: recurving distributor [Re: Dougsmopars] #443115
08/19/09 09:09 PM
08/19/09 09:09 PM
it likes 20 initial. Shorten the slots to give 16-18 more, then use as light of springs as it will take wo pinging at WOT then connect the vac adv and give it as much adv as it will take(CW with a 3/32" allen wrench) wo pinging at part throttle
Re: recurving distributor [Re: RapidRobert] #443116
08/20/09 12:16 AM
08/20/09 12:16 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
why dont you just change the cam?
Re: recurving distributor [Re: Dougsmopars] #443117
08/20/09 12:54 AM
08/20/09 12:54 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
The initial timing is to provide a clean idle and crisp throttle response. Based on the degree of the camshaft, 10- to 12-degrees of initial timing when the duration of the camshaft is less than 220-degrees @ 0.050” of valve lift; 14- to 16-degrees of initial timing with a camshaft duration of less than 240-degrees @ 0.050”; and 18- to 20-degrees of initial timing when the camshaft duration is less than 260-degrees @ 0.050” of valve lift.
As engine revs increase, it is necessary to advance the ignition timing. If not, the burning process in the combustion chamber would take longer than the speeding piston would permit, resulting in an incomplete burn. To give the burning process a head start, an ignition advance mechanism is provided within the distributor. It is activated by engine revs and by the centrifugal force generated through the weights and springs within the distributor. Consequently, as the engine revs increase so, too, does the advancement of the ignition. The ignition advance mechanism operates either as a mechanical/centrifugal advance only or as a mechanical/centrifugal advance with vacuum assistance. Mechanically operated distributors are usually associated with high-performance and racing engines; vacuum-assisted distributors are chosen for their improved fuel economy and exhaust emissions. Vacuum timing is controlled by the vacuum or depression in the intake manifold and flourishes under light loads. Under acceleration, however, the vacuum in the manifold weakens as the throttle plates of the carburetor open and the ignition advance reverts to the control of the mechanical/centrifugal mechanism. With either design, the timing advance mechanism should not begin advancing before 1,000 rpm and, usually, full advance will have occurred before 3,500 rpm. Too much advance while the engine speed is low can cause harmful pinging or detonation; too little advance as engine revs increase will demonstrate a lack of power. The rate at which the timing advance occurs is referred to as the advance curve. The advance curve used on most production engines and on aftermarket distributors is designed to allow an engine to operate under a wide range of conditions (flat terrain, hilly terrain, towing, fluctuations in the quality of fuel, etc). As a consequence, ignition advance curves tend to be conservative for general use.
POINTS TO REMEMBER
Retarded or insufficient timing advance will cause an engine to lack power. Conversely, excessive timing advance can also cause a lack of engine power but, worse, it can lead to overheating and costly damage from detonation. In many cases, the advance curve of a distributor may not be appropriate for today’s fuels or the engine combination that is being used. Many performance replacement distributors exhibit very slow advance curves; however, they’re usually supplied with an assortment of bushings and springs to facilitate a more rapid curve. The bushings regulate the amount of timing advance; the springs regulate the rate of timing advance. Whether the distributor is an original or a performance replacement unit, it’s prudent to have it checked to ensure its proper operation and its suitability for the vehicle. A rich air/fuel mixture that produces its maximum power at, say, 12.5:1 requires less advance timing than a leaner air/fuel mixture of, say, 14.0:1 (a typical hot rod AFR at cruising speeds). In the former example, extra power is realized by the richer air-fuel mixture; in the latter, economy is achieved by the action of the
vacuum advance mechanism. The reason an engine can exploit the additional spark advance provided by the vacuum advance mechanism is because the leaner air/fuel mixture, occurring at light throttle cruising speeds, takes longer to burn than a richer air/fuel power mixture. In most cases, when using a “hot rod mechanical advance curve,” the desired amount of additional advance generated by the vacuum advance mechanism is around 10-degrees. This additional 10-degrees of advance timing should occur with 10-inches of vacuum or more.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: recurving distributor [Re: Baxter61] #443118
08/20/09 04:55 PM
08/20/09 04:55 PM
why would i want to change the cam? Car runs super with correct advance curve. Wicked tire frier. Recurving the dist was much easier then swapping a cam. Motor makes a ton of power why would i want to lose that over a timing issue?
