Re: 99 Dodge Ram dies
[Re: Curt57]
#442496
08/19/09 09:32 AM
08/19/09 09:32 AM
RapidRobert
When it dies it will still turn over w the key? Under the dash I'd check the various connections in the harness at the ign sw, ammeter, the fuse box etc & pull apart the connectors looking for the wire that is loose/corroded. EDIT if it just only died I'd check the bulkhead 1st but w the dash lights going out also I'd go under the dash
[Re: RapidRobert]
#442497
08/19/09 09:55 AM
08/19/09 09:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Sounds like the vehicles CCD bus is going down.
