99 Dodge Ram dies #442494
08/18/09 10:10 PM
08/18/09 10:10 PM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
Iv'e got a 99 Ram 318. It will die with no warning or pattern. It may go a day,a week ,or a month between times. When it dies , the dash goes dead too. All the gauges go flat and lights go out. The starter will turn. But no spark. Any ideas PLEASE. THANKS, Curt
Re: 99 Dodge Ram dies [Re: Curt57] #442495
08/19/09 08:09 AM
08/19/09 08:09 AM
Curt57 Offline OP
Curt57  Offline OP
Re: 99 Dodge Ram dies [Re: Curt57] #442496
08/19/09 09:32 AM
08/19/09 09:32 AM
When it dies it will still turn over w the key? Under the dash I'd check the various connections in the harness at the ign sw, ammeter, the fuse box etc & pull apart the connectors looking for the wire that is loose/corroded. EDIT if it just only died I'd check the bulkhead 1st but w the dash lights going out also I'd go under the dash
Re: 99 Dodge Ram dies [Re: RapidRobert] #442497
08/19/09 09:55 AM
08/19/09 09:55 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Sounds like the vehicles CCD bus is going down.
Re: 99 Dodge Ram dies [Re: gdonovan] #442498
08/19/09 01:06 PM
08/19/09 01:06 PM
Curt57 Offline OP
Curt57  Offline OP
OK whats the CCD bus
