Bee Front grill ???'s w/pictures! #442223
08/18/09 06:53 PM
08/18/09 06:53 PM
Anonymous OP
Anonymous OP
Ok, how the heck do I get the top bolts in my 70 bee grill? When I have the black insulators installed there is no humanly possible way to get the upper carriage bolts in. Without the black piece the slide right together. And.....photos
Re: Bee Front grill ???'s w/pictures! #442224
08/19/09 11:28 AM
08/19/09 11:28 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
What do you mean by insulators? the rubber bumper (which needs to be loose until the whole thing is in position) or the black plastic spacers that attach to the chrome bumper hoops?
Judging from the wheels and paint, you probably don't care, but the correct way for the bolts to be installed is from below with the nuts showing on the top; most restos get this wrong.
Those '70 Coronet front ends are a bit of a beotch aren't they?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Bee Front grill ???'s w/pictures! [Re: DPelletier] #442225
08/19/09 11:41 AM
08/19/09 11:41 AM
DPelletier Offline
DPelletier  Offline
On second glance, I think I see your problem. I believe you need to assemble the bumpers, spacers and the upper and lower braces (along with the vertical grill supports) as an assembly and then slide the finished assembly in place so you can install the final bolts to the upper and lower frame brackets......at least that's how I did it and it worked.
Cheers,
