Re: 318 and 360 motor mount, the same?
[Re: dirt]
#44219
08/27/07 05:24 PM
08/27/07 05:24 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
They are not the same. However you can use the 318 mount which you can actually buy on a 360 with some spacers. I believe its about .250 in. spacer.
Back in the swing of things at Painless again! Great to be back!
[Re: dirt]
#44221
08/27/07 09:25 PM
08/27/07 09:25 PM
Posts: 17,861 albany ny
05dakota
albany ny
sonds like you are talking about the rubber isolator and he is talking about the bracket bolted to the block.
5549 post on old board
[Re: 5thAve]
#44223
08/27/07 10:52 PM
08/27/07 10:52 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Yeah to use a 318 mount on a 360 you've gotta shim it at the back hole. I've done this on Truck brackets without issues. I just threw an old nut in there to take up the space.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MoPar Jamie]
#44224
08/28/07 03:32 PM
08/28/07 03:32 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Pic....
[Re: RodStRace]
#44226
08/28/07 04:25 PM
08/28/07 04:25 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
A-body 1968-1972 340-360 uses 1 drivers side steel bracket. here is a pic(Will also fit 1967 A-body V8 k-frame)
