rear leaf spring RUBBER ISOLATORS same b and C body? #442158
08/18/09 04:49 PM
08/18/09 04:49 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
C body part # is 3400543 for 71 i dont have a later parts book to compare with the B body ones anyone have any idea? dan
Re: rear leaf spring RUBBER ISOLATORS same b and C body? [Re: ph23vo] #442159
08/18/09 04:55 PM
08/18/09 04:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
3402379 is 72 and up. I have a set of poly for sale if they will fit your 71.
Re: rear leaf spring RUBBER ISOLATORS same b and C body? [Re: mopars4ever] #442160
08/18/09 05:05 PM
08/18/09 05:05 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
could you measure em and maybe send me a pic with some specs? i havent taken mine apart yet i was doing the rear brakes and saw they were rotted thank dan
Re: rear leaf spring RUBBER ISOLATORS same b and C body? [Re: ph23vo] #442161
08/18/09 05:31 PM
08/18/09 05:31 PM
md
mopars4ever Offline
mopars4ever  Offline
md
spring width opening is about 2 1/2, length is about 6 1/4. They are still sealed in the package.
Re: rear leaf spring RUBBER ISOLATORS same b and C body? [Re: mopars4ever] #442162
08/18/09 06:36 PM
08/18/09 06:36 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i bet i could make those work lmk $$ dan
