72 E body fuses #442032
08/18/09 02:15 PM
08/18/09 02:15 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
It's been a while since I had to replace any fuses in the Cuda. What size (length) are the fuses in the block 1" or 1-1/4 ???
I want to pick some up on the way home from work.
Re: 72 E body fuses [Re: 340KID] #442033
08/18/09 02:22 PM
08/18/09 02:22 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The size is a 3AG or also known as AGC..
Usually their values were 10A, 15A, 20A, 25A
Just my $0.015...
Re: 72 E body fuses [Re: Sinitro] #442034
08/18/09 02:24 PM
08/18/09 02:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
every one is 20amps, but one being 5 amps. That is at least on B bodies... E bodies uses same fusebox
Re: 72 E body fuses [Re: NachoRT74] #442035
08/18/09 02:26 PM
08/18/09 02:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
AGC is the type you need.
Re: 72 E body fuses [Re: Challenger 1] #442036
08/18/09 02:33 PM
08/18/09 02:33 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Thanks everyone
