carb to trans linkage?? #442021
08/18/09 01:07 PM
08/18/09 01:07 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
whats the trick? by the book i think i have it adj. correctly, but shifts too quickly, by the book it is the correct linkage, what might i be overlooking?? 69 340 cuda.
Re: carb to trans linkage?? [Re: Lew] #442022
08/18/09 01:17 PM
08/18/09 01:17 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Give it a little more preload.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: carb to trans linkage?? [Re: Pentastar440] #442023
08/18/09 01:33 PM
08/18/09 01:33 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
i think i have it maxed out, but i will check, thanks.
Re: carb to trans linkage?? [Re: Lew] #442024
08/18/09 03:42 PM
08/18/09 03:42 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
What do you consider "too early"? The factory spec for light throttle shifts is pretty low, in top gear before 20 mph.
Is the carb stock?
