Radiator question #442018
08/18/09 01:00 PM
08/18/09 01:00 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
My 65 Satelite was running hot so I pulled the rad and brought it to a local shop they want $488 to recore it. That seems a lot higher than I expected. Looks like 22" replacements are not available, but 26' are for about $300. Any problems using a 26" with a 22" opening? Summit has an aluminum cross flow for $329, but I'm not sure what to do about a fan shroud. If I go with an electric fan that means an alternator upgrade so the cost for the rad, alternator and fan will be over $500 anyway. Thoughts?
Re: Radiator question [Re: JM67RT] #442019
08/18/09 02:18 PM
08/18/09 02:18 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Sounds high..
I had a new Modine core put in my 70RR they used my top/bottom tanks and it was about $300. You mite check out www.manciniracing.com
they carry some very nice aluminum direct-bolt-in radiators..
Just my $0.015...
Re: Radiator question [Re: JM67RT] #442020
08/18/09 02:31 PM
08/18/09 02:31 PM
brought it to a local shop they want $488 to recore it. Thoughts?
No way 488 to recore it. I'd get a new one that fits & looks good in there
