Engine builders, I could use some advice
#441989
08/18/09 12:42 PM
08/18/09 12:42 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I have a Muscle Motors built 474 stroker with Mopar Stage 6 heads and a Comp Cam .625 lift roller cam, Crane gold rockers (I'm pretty sure 1.5 ratio) I am beginning to suspect that my valve springs are getting weak, the car is slowing both et and mph. It makes little or no difference if I shift (4-speed) at 5800 or 6500 rpm. I've experimented with timing, shift points, etc without much change. The motor is pretty old but with a small amount of runs/miles (meaning that it has sat a lot). I have heard that you need to relieve the pressure from the springs for lay-ups but have never done it. I don't have the equipment to check the springs so I am thinking replacing them would be just as cheap as buying the tools. My questions are: 1) What springs do I need (part numbers would really help)? 2) Does someone make a tool where I can charge the cylinder with air and remove/replace the springs? Thanks in advance, Mike
Re: Engine builders, I could use some advice
[Re: mike67net]
#441990
08/18/09 12:51 PM
08/18/09 12:51 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
A compression checker or a leak down tester will have a air line that will thread into your head to keep the valves closed. Also I think Mancini Racing sells a on head valve spring remover. Of course all of this would cost about the same as a spring tester and you can know for sure if your springs are weak or not.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: mike67net]
#441992
08/18/09 01:27 PM
08/18/09 01:27 PM
Posts: 705 Michigan
Hemiroid
You can build a hose for airing up cylinders from Milton fittings found at auto parts stores or use a hose from a leak/comp checker as stated above. You can also remove the plug and thread in some nylon rope with the piston down in the hole, then run the piston up towards tdc until the rope meets the chambers/valve heads and stops. Works quite well, done it a million times.
As for the springs, Comp 943's or Isky 9935's.
[Re: Hemiroid]
#441993
08/18/09 02:00 PM
08/18/09 02:00 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You dont have a local machine shop to do any work for you? It takes very little time to test a few valve springs. They probably wont charge you a dime if you take the spring to them. No need to take them all. Take 3-4 intake springs, and 3-4 exh springs.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#441995
08/18/09 09:11 PM
08/18/09 09:11 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Just be sure you have the installed height and cam lift info with you otherwise it's a waste of time.
[Re: mike67net]
#441996
08/18/09 09:44 PM
08/18/09 09:44 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My questions are:
Thanks in advance,
Mike
Check the springs. Buying tools is an investment in your garage and car. replacing springs that didn't need it is money out the window.
[Re: Bob_Coomer]
#441999
08/18/09 11:40 PM
08/18/09 11:40 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
If he knows the part number of the springs shouldnt they be with in 10-15 lbs of list spec? just saying.
Actually I don't have the part number of what's in the motor now. The paperwork I have just shows "Isky roller" listed for valve springs. I have no specs on them.
[Re: mike67net]
#442000
08/18/09 11:54 PM
08/18/09 11:54 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Some of the old(not the new ones like the toool room springs) Isky "roller" BB Mopar springs where pretty weak out of the boxes 200 to 225 lbs on the seats and barely 475 lbs open with .600 net lift set up to be within .060 of coil bind ,not worth a hoot, IMO. Have some of yours checked before doing anything else, as already suggested I have learned from some very good racers that more valve spring pressure(250LBs+ on the seats and 600LBS + over the nose) on roller cams and lifters is way better than not quite enough, especially in a drag race motor with heavy valves like most of our motors have
[Re: mike67net]
#442002
08/19/09 10:26 AM
08/19/09 10:26 AM
Thumperdart
State of confusion
If you know your installed height, I would ask for Rod at Isky and see what he suggests.......tell him Dominic sent ya!
[Re: Thumperdart]
#442003
08/19/09 10:41 AM
08/19/09 10:41 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I was just trying to figure that out. How do you determine that, will measuring the old ones tell me?
Mike
[Re: Cab_Burge]
#442004
08/19/09 11:18 AM
08/19/09 11:18 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
Cab, thanks for giving me a baseline on what I need. The old springs you speak of, is that what came on Stage 6 heads? I believe that may be what MM used.
[Re: Greg]
#442006
08/19/09 11:28 AM
08/19/09 11:28 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
Mike,
Where are you located in Ohio? I know a few guys that can help you.
I'm in northeast Ohio, 44026
[Re: mike67net]
#442007
08/19/09 04:33 PM
08/19/09 04:33 PM
Thumperdart
State of confusion
If you don`t have a valve spring mike then you need to put a retainer and locks on the valve and crank up on w/your fingers and measure the distance from the head/spring cup to the bottom/inside of the retainer and shoot em that number.
