Re: 1970 440 six pack block
[Re: 70 v code]
#441943
08/18/09 02:13 PM
08/18/09 02:13 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
i like your sign. i stopped by a local machine shop that built my 44o six pack eng and he had found a block in the back of the shop that is an hp some expert called him and told to look for extra web reinforcements that all six pack engines have (not!) and that because it has a f in front of the 440 it is a six pack motor (not) i was pretty sure unless you had the car there was know way to tell. i heard that all six pack engines have a c stamped on the pad for special pistons but who knows?
I do! My original #'s 1970 six pack engine is stamped F440 HP2 and the date and that's IT, no "C".
Just for the record; F means 1970 and HP2 means "High Performance, Second Shift". 6 pack blocks can be HP or HP2 stamped, just like 440 375hp 4 barrel motors. Even the so called "6 pack rods" and related balancer are used in ALL HP motors in 1970. There ARE ways to tell on an original, unmolested, never apart motor such as the pistons, cam and timing set and intake and carbs, but it's pretty hard to PROVE that stuff is original some 40 years after the fact.......which takes us back to my pic!
99% of the blocks advertised as "six pack blocks" are really impossible to say one way or the other and it's the ploys of unscrupulous sellers and the proliferation of some of the "six pack" urban legends that keep this question at the top of the "most frequently asked questions" list.
Tell your machine shop dude you were right.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
