Best E-85 Fuel pump?????? #441908
08/18/09 09:32 AM
08/18/09 09:32 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Whats the best E-85 fuel pump for a 900 hp 9500 rpm engine??
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Best E-85 Fuel pump?????? [Re: DemonDust] #441909
08/18/09 09:47 AM
08/18/09 09:47 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Best? I didn't know there was different grades of e-85 or do you mean brand of station?
Re: Best E-85 Fuel pump?????? [Re: rowin4] #441910
08/18/09 09:50 AM
08/18/09 09:50 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
He is talking about compatability with race fuel pumps.
I don't know but there are guys on turbomustangs.com using E85. You might give them a shout.
Re: Best E-85 Fuel pump?????? [Re: Shaker223] #441911
08/18/09 09:58 AM
08/18/09 09:58 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
With all the asking I did in this department I was given two answers. Belt Drive Mechanical Pump or the Magnafuel pump that is infact there mechanical pump with a electric motor mounted to it...
Re: Best E-85 Fuel pump?????? [Re: DemonDust] #441912
08/18/09 10:06 AM
08/18/09 10:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Base your pump on the same factors as gas BUT use
the 30% greater flow as the minimum and you'll be
more than fine
PM me so I can get your engine specs and I can figure
your fuel demands
Re: Best E-85 Fuel pump?????? [Re: joshking440] #441913
08/18/09 10:10 AM
08/18/09 10:10 AM
Menomonee Falls
Menomonee Falls
Yes I'm talking about the fuel pump for the car.
Nascar uses a billet mechanical piece that supplies their 830 hp engines. They said If I use a CV products red diaphragm it won't be a problem. They just can't give me an answer if the E-85 is gonna affect the pump, and if it does how long it will last, they said " I don't think it will bother it" The diaphragm is only like $25. So if I have to replace it once a year I'm thinking no big deal. Just wanted to see what other people were using and what is out there. Cause if I start going thru diaphragms once a month I'll buy an electric.
SDG Motorsports
Re: Best E-85 Fuel pump?????? [Re: DemonDust] #441914
08/18/09 10:17 AM
08/18/09 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I am 2 years on my Holley black 150s, I have a pair
of them in parallel. E-85 has 15% gas in it to act
as a lubricant for seal life... with the studies we
did at Chrysler it had very little corrosion aspects
Re: Best E-85 Fuel pump?????? [Re: DemonDust] #441915
08/18/09 10:21 AM
08/18/09 10:21 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I think nascar's pumps are in the trunk and cable driven.
Re: Best E-85 Fuel pump?????? [Re: BobR] #441916
08/18/09 10:25 AM
08/18/09 10:25 AM
Menomonee Falls
Menomonee Falls
Nope on the block just like the LA blocks
SDG Motorsports
Re: Best E-85 Fuel pump?????? [Re: DemonDust] #441917
08/18/09 11:18 AM
08/18/09 11:18 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Any pump that will support your flow needs.
