Re: Best E-85 Fuel pump??????
[Re: DemonDust]
#441912
08/18/09 10:06 AM
08/18/09 10:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the best E-85 fuel pump for a 900 hp 9500 rpm engine??
Base your pump on the same factors as gas BUT use the 30% greater flow as the minimum and you'll be more than fine PM me so I can get your engine specs and I can figure your fuel demands
[Re: DemonDust]
#441914
08/18/09 10:17 AM
08/18/09 10:17 AM
MR_P_BODY
Yes I'm talking about the fuel pump for the car.
Nascar uses a billet mechanical piece that supplies their 830 hp engines. They said If I use a CV products red diaphragm it won't be a problem. They just can't give me an answer if the E-85 is gonna affect the pump, and if it does how long it will last, they said " I don't think it will bother it" The diaphragm is only like $25. So if I have to replace it once a year I'm thinking no big deal. Just wanted to see what other people were using and what is out there. Cause if I start going thru diaphragms once a month I'll buy an electric.
I am 2 years on my Holley black 150s, I have a pair of them in parallel. E-85 has 15% gas in it to act as a lubricant for seal life... with the studies we did at Chrysler it had very little corrosion aspects
[Re: DemonDust]
#441915
08/18/09 10:21 AM
08/18/09 10:21 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I think nascar's pumps are in the trunk and cable driven.
[Re: BobR]
#441916
08/18/09 10:25 AM
08/18/09 10:25 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Nope on the block just like the LA blocks
