Anyone use Synthetic brake fluid in their drag cars
#441802
08/18/09 07:47 AM
08/18/09 07:47 AM
Posts: 1,973 SoCal
jake4cars
SoCal
Re: Anyone use Synthetic brake fluid in their drag cars
[Re: 47hudson]
#441804
08/18/09 07:59 AM
08/18/09 07:59 AM
Posts: 428 wappinger falls new york
Jimi_Vignogna
We have been running DOT5 in Dads car for years and I am running it in mine as well. We have had no problems. I like that it does not ruin your paint if it leaks or get spilled.
dot 5 is non hydroscopic,but it has a lower boiling point than dot 3, i use dot 5 in all of my cars, i have never had a problem with the dot 5.
[Re: jake4cars]
#441806
08/18/09 08:49 AM
08/18/09 08:49 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Synthetic or silicone??
There are synthetic versions of DOT 3, 4 & 5.1.
DOT 5 is silicone.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#441809
08/18/09 10:07 AM
08/18/09 10:07 AM
Posts: 8,165 Left Coast
BobR
Left Coast
DOT 5 is silicone.
Exactly. Two different animals.
[Re: BobR]
#441810
08/18/09 07:51 PM
08/18/09 07:51 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use Valvoline's SynPower synthetic brake fluid in the Demon,and the Road Runner has Dow Corning silicone fluid in it.
I went with the Valvoline in the race car as Wilwood said not to use silicone fluid in it's brakes.
[Re: Chris2581]
#441811
08/19/09 10:02 AM
08/19/09 10:02 AM
BobR
Left Coast
I have Wilwoods and I have Dot5 fluid in them-as well as everything else I own. I don't like the idea of having paint stripper inside my car.
[Re: Lil Demon]
#441813
08/19/09 05:01 PM
08/19/09 05:01 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
LilDemon,
I bought Aerospace years ago for the Cuda and just started putting the front end back under it. I am glad you posted this about using Dot 3.
I put DOT 5 in the GTS, and it saved my paint! I had just bled the master cylinder and had forgot to put the top back on. Got in the car and when I pressed the pedal, it blew fluid up and all over the freshly painted firewall!
I was going to use the same stuff on in the Cuda with my aerospace brakes! You probably just saved me a lot of trouble!
Now I need to figure out what seals I need for the hubs. for some reason they did not come with seals and bearings. It has been so long, I can't find my paperwork anywhere. Parts houses here are useless. You go in with measurements and ask for seals and they look like you just spoke to them in Chinese or something hehehehe.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: jcc]
#441817
08/21/09 12:33 AM
08/21/09 12:33 AM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
I put dot 5 in my 440 powered 27 T pickup hotrod all brake parts new the stuff had a soft pedal and was seeping out of everywhere my wheel cylinders, line lock, master, brake line fittings! Got it from napa their brand not impressed was a pain to get it out and flushed put in dot 3 good hard pedal no more leaks????? LAST TIME I TRY DOT 5
ACCELERATION SPECIALIST
