Brighter dash cluster lamps or white LED's? #441775
08/18/09 07:44 AM
08/18/09 07:44 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Has anyone tried making their cluster lamps brighter with some sort of drop in replacement bulb that is brighter or white LED's?
I hate the cluster on my Duster it is so dark and all the bulbs are new and the voltage is good. I'm thinking of adding a few white LED's to the cluster to brighten it up.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441776
08/18/09 11:17 AM
08/18/09 11:17 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Those little dash light bulbs come in different brightnesses but I don't know the number for the brightest one.
Re: Brighter dash cluster lamps or white LED's? [Re: stumpy] #441777
08/19/09 03:38 PM
08/19/09 03:38 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I ended up going to Wal-Mart and getting three different bulb sizes.
Stock size is 194 which is 4-5 watts
908 is next brightest
212 is 14 watts
221 is HD version of 212
908/212/221 is larger that 194 and just touches the back of the speedo head.
Ended up going with the 221 bulbs, I can SEE those gauges now! The dimmer control actually has some function now
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441778
08/19/09 06:25 PM
08/19/09 06:25 PM
Medford OR
FrankenScamp Offline
Medford OR
Good to know....next time a bulb goes out I'll swap them all out with the brighter ones!!
Re: Brighter dash cluster lamps or white LED's? [Re: FrankenScamp] #441779
08/19/09 07:10 PM
08/19/09 07:10 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
What does that do as far as heat inside the cluster? Do the brighter bulbs fit inside the little colored domes on the interior of the cluster? Id hate to start melting stuff in there
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Brighter dash cluster lamps or white LED's? [Re: 69L78Nova] #441780
08/19/09 07:56 PM
08/19/09 07:56 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
My car (Duster) is not equipped from the factory with the domes.
If you have a car with domes the larger bulbs will not work.
I'd like to give LED's a try and will look into it and report.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441781
08/19/09 11:50 PM
08/19/09 11:50 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I'm running all LED's in my Darts dash, I tried the LED replacement for 194's and wasn't impressed so I built a string of LED's and ran it to the fusebox,
For mounting I used the stock plastic bulb holder that I drilled a hole thru the back for the wire to pass thru and glued the LED in with some silicone. About the only downside is you lose the dimming feature but the lighting is much better and it doesn't pull as many amps.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441782
08/24/09 11:04 PM
08/24/09 11:04 PM
Queens,NY
Bogie Offline
Bogie  Offline
Queens,NY
66 Dart 170 Post 273HP/4 Spd 3.90's 84 w350 Crew Cab 360/4 Spd 4.10's 7" Lift 37" Super Swampers 91 Wrangler 4.0 For Sale - 2500 OBO Must GO 94 Grand Cherokee Laredo 4.0
Re: Brighter dash cluster lamps or white LED's? [Re: Bogie] #441783
08/25/09 12:38 AM
08/25/09 12:38 AM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
Which ones are you using? Superbright has many many diff sizes and intensities
PLAZ
Re: Brighter dash cluster lamps or white LED's? [Re: plazomat] #441784
08/25/09 01:39 AM
08/25/09 01:39 AM
Queens,NY
Bogie Offline
Bogie  Offline
Queens,NY
That cluster has white WLED-xHP6
Re: Brighter dash cluster lamps or white LED's? [Re: Bogie] #441785
08/25/09 09:16 AM
08/25/09 09:16 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Bogie, it appears your truck is running, why no voltage?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Brighter dash cluster lamps or white LED's? [Re: Magnumguy] #441786
08/25/09 05:44 PM
08/25/09 05:44 PM
Queens,NY
Bogie Offline
Bogie  Offline
Queens,NY
Sorry guys not my cluster just one of the guys on DTR who did the conversion I have a earlier truck and did the same setup but using white face gauges I just don't have any pics.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441787
08/25/09 05:58 PM
08/25/09 05:58 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
What the Poster isn't telling you is he's 1/2 blind in one eye and can't see very well out of the other and has no business driving at night so the extra bright dash lights will only distract him from focusing on objects in the road.
Ask him about the 67 Dart headers smacking into the manhole cover he hit one night or the poor little rabbit he took out years ago on I-95...
Hi ya buddy
Seriously, I really like the look of those LEDs in the pic above, very cool.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441788
08/31/09 07:18 PM
08/31/09 07:18 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
212 is 14 watts
What brand are the 221's you found. I've been on the Sylvania website and can't find any listings for a 908, 212 or 221 bulb that will fit a 194 hole. PepBoys and Kragen don't even carry them.
I wanna see my gauges too
Maggot
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Brighter dash cluster lamps or white LED's? [Re: ChickMaggot] #441789
08/31/09 08:50 PM
08/31/09 08:50 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I'll dig up the info for you.
Re: Brighter dash cluster lamps or white LED's? [Re: Bogie] #441790
08/31/09 11:02 PM
08/31/09 11:02 PM
plazomat Offline
plazomat  Offline
What color cool white or warm white?
Just wondering what made you choose that form factor?
PLAZ
Re: Brighter dash cluster lamps or white LED's? [Re: plazomat] #441791
08/31/09 11:37 PM
08/31/09 11:37 PM
Queens,NY
Bogie Offline
Bogie  Offline
Queens,NY
Cool White and there the brightest they have that cover in all directions
Re: Brighter dash cluster lamps or white LED's? [Re: 69L78Nova] #441792
09/04/09 07:08 PM
09/04/09 07:08 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
LEDs run much cooler than incandescent bulbs.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441793
09/04/09 10:59 PM
09/04/09 10:59 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Any update on a brand name?
I still haven't been able to find any
Re: Brighter dash cluster lamps or white LED's? [Re: Lefty] #441794
09/04/09 11:17 PM
09/04/09 11:17 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
The Sylvania site has this for the instrument lights on a 69 GTX:
Instrument-general
1893
194
53
57
So which ones do I use on my instrument panel?
