At what ET do you need a roll bar in the 1/8th?? #441702
08/17/09 11:35 PM
08/17/09 11:35 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I know it's 11.49 in the quarter mile, but what about the 1/8 mile? I don't recall seeing any mention of 1/8 mile in the rule book. What conversion factor (1/8-1/4) does the NHRA use? Different sources seem to use slightly different numbers for converting.
thanks
codfish
Re: At what ET do you need a roll bar in the 1/8th?? [Re: codfish] #441703
08/17/09 11:46 PM
08/17/09 11:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IIRC 7.35 in the 1/8.
Re: At what ET do you need a roll bar in the 1/8th?? [Re: justinp61] #441704
08/18/09 09:58 AM
08/18/09 09:58 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Re: At what ET do you need a roll bar in the 1/8th?? [Re: justinp61] #441705
08/18/09 10:57 AM
08/18/09 10:57 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I think you right 7.35 in the 1/8th.
Re: At what ET do you need a roll bar in the 1/8th?? [Re: 70dusterjohn] #441706
08/18/09 11:17 AM
08/18/09 11:17 AM
sweden
sshemi Offline
sshemi  Offline
sweden
havent they changed it to faster than 11.00?
That would be around 7.0 in the 1/8
Re: At what ET do you need a roll bar in the 1/8th?? [Re: sshemi] #441707
08/18/09 11:22 AM
08/18/09 11:22 AM
Deerfield, Ohio
Deerfield, Ohio
you might be right..
Re: At what ET do you need a roll bar in the 1/8th?? [Re: sshemi] #441708
08/18/09 12:30 PM
08/18/09 12:30 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Wasn't it just three years ago or so that it was changed from 11.99 to 11.49?
If it's been changed to 11 or quicker, it musta been a REAL recent change.
codfish
Re: At what ET do you need a roll bar in the 1/8th?? [Re: codfish] #441709
08/18/09 12:41 PM
08/18/09 12:41 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
10.99 and 6.99 are the when you are required to have a cage versus the bar.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: At what ET do you need a roll bar in the 1/8th?? [Re: Irun5snd8th] #441710
08/18/09 12:44 PM
08/18/09 12:44 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Would you know when a BAR is needed in the 1/8th?
thanks
codfish
Re: At what ET do you need a roll bar in the 1/8th?? [Re: codfish] #441711
08/18/09 12:55 PM
08/18/09 12:55 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
7.50 for the roll bar in the 1/8th.
Re: At what ET do you need a roll bar in the 1/8th?? [Re: codfish] #441712
08/18/09 01:01 PM
08/18/09 01:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you my last time out I ran 11.55 with a 1.59 sixty and the 1/8 was a 7.30. Ron
Re: At what ET do you need a roll bar in the 1/8th?? [Re: 383man] #441713
08/18/09 01:12 PM
08/18/09 01:12 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
My best so far, at the airport races here, was 7.31@96 MPH. Hoping to better that a little next weekend.
But in 4 weeks I'm going to a real track. With the last combo (360/904 and 4.57s), I picked up three tenths by going to a track versus the airport. NO changes what so ever.
With the new combo (stroked RB, 727, and dana with 3.73s), I hope to pick up at least the same.
thanks
codfish
Re: At what ET do you need a roll bar in the 1/8th?? [Re: codfish] #441714
08/18/09 01:20 PM
08/18/09 01:20 PM
sweden
sshemi Offline
sshemi  Offline
sweden
rulebook says 9.99 and quicker you need a cage.
Tech here in sweden says 10.99 and quicker you need a bar.
Re: At what ET do you need a roll bar in the 1/8th?? [Re: sshemi] #441715
08/18/09 02:29 PM
08/18/09 02:29 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Rulebook actually states cage must be certified at 9.99 or quicker. Cage required at 10.99 unless all the original floor and firewall is in place excluding wheel tubs.
Here is the actual verbage and the answer to the original question is 7.49
4.5 ROLL BAR
Roll bar mandatory in all cars running 11.00 (*7.00) to 11.99 (*7.49) and in convertibles running 11.00 (*7.00) to 13.99 (*8.59), and in dune-buggy type vehicles running 12.00 (*7.50) seconds and slower. Permitted in all cars. See General Regulations 4.10, 10.6.
4.6 ROLL CAGE
Roll cage mandatory in cars running 10.99 (*6.99) or quicker, or any car exceeding 135 mph (217.2 km/h). Full bodied cars, with unaltered firewall, floor and body (from firewall rearward, wheeltubs permitted), running between 10.00 (*6.40) and 10.99 (*6.99) roll bar permitted in place of roll cage. Cars running between 7.50 (*4.50) and 9.99 (*6.39) must have chassis inspected every three-years by the ASN and have a serialised sticker affixed to cage before participation. Must conform to specs for body style used, as listed in General Regulations 4.11, 10.6.
Re: At what ET do you need a roll bar in the 1/8th?? [Re: Irun5snd8th] #441716
08/18/09 02:35 PM
08/18/09 02:35 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Darn it Eric, I liked the sound of 7.35 better! Was it maybe 7.35 a couple years ago?
Re: At what ET do you need a roll bar in the 1/8th?? [Re: Cuda_Mike] #441717
08/18/09 02:52 PM
08/18/09 02:52 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Does that meen that you dont need anything running slower than 10.99 or 6.99?
Re: At what ET do you need a roll bar in the 1/8th?? [Re: sshemi] #441718
08/18/09 03:10 PM
08/18/09 03:10 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
NO - It means that if you DON'T have a stock floor pan/firewall, you need a roll cage at 10.99 not 9.99 (6.99 not 6.40).
As Eric stated - Roll bar is required from 11.49 (7.49) to 10.00 (6.41) as long as you have a stock firewall and floor pan
(minor mods usually considered OK - no gaping holes or having large panels replaced. Welded or bolted covers over wiper openings, heater holes, etc. are OK.)
As a CURRENT NHRA SFI Certified Safety Technician, I agree with the above statements made by Mr. Eric Paul (Irun6snd8th) LOL
