727 washer between input and output shaft #441612
08/17/09 10:56 PM
08/17/09 10:56 PM
Red Bluff, CA
W
WilliamHall Offline OP
super gas
super gas
W
Red Bluff, CA
I have a 1978 transmission that I am rebuilding and I cant remember if there was 1 bronze washer between them or a thinner metallic washer or both? The 727 Rebuild book says there should have been a plate and washer but what is a plate and how does it look?
Re: 727 washer between input and output shaft [Re: WilliamHall] #441613
08/18/09 03:49 PM
08/18/09 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '78 should have a 3-eared babbit thrust washer which matches the three pockets in the rear clutch retainer and a thin steel washer that goes on the output shaft pilot.
The pic below shows the two in the top of the pic.
Re: 727 washer between input and output shaft [Re: John_Kunkel] #441614
08/18/09 03:50 PM
08/18/09 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The matching pocket in the rear clutch retainer.
