rear disc master cylinder #441597
08/17/09 10:33 PM
08/17/09 10:33 PM
Wisconsin
1964maxwedge Offline OP
Wisconsin
Does anybody no where I can buy master cylinder with manual brake without spending over a 100.00 for one.What I'm working on is a 1964 dodge b body all wheel disc
thanks
Re: rear disc master cylinder [Re: 1964maxwedge] #441598
08/17/09 11:19 PM
08/17/09 11:19 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I went to my local auto parts store, got one for my 67 Coronet with disc brakes front and then put a wilwood pressure valve on the rears, with the stock prop valve.. It worked okay, but latter I install an adjustable on the rear.. Hope this helps.
Re: rear disc master cylinder [Re: 70dusterjohn] #441599
08/17/09 11:24 PM
08/17/09 11:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I think I have about $40 in my reman master cylinder and reservoir. The master came from NAPA and the reservior from Auto Zone, it's a 1 1/32" bore.
Re: rear disc master cylinder [Re: justinp61] #441600
08/17/09 11:40 PM
08/17/09 11:40 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
http://www.quartermax.com/details.php?prodID=414&catID=85
This is what I have in my car if you want a good racing brand designed for 4 wheel discs. STRANGE Use the pull down menu to choose bore size. Mark Willianms said to get the 1-1/8" bore so I did.
SRT DEMON ONE SEAT
Re: rear disc master cylinder [Re: Ron Silva] #441601
08/18/09 03:47 AM
08/18/09 03:47 AM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
thats the same one i am using..Strange...
Re: rear disc master cylinder [Re: BILLYJAY] #441602
08/18/09 11:21 AM
08/18/09 11:21 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Me too
Good thing is you get the pushrod and fittings witch some MCs doent include.
Re: rear disc master cylinder [Re: sshemi] #441603
08/18/09 02:02 PM
08/18/09 02:02 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Go to the local junk yard and pull the master cylinder off of a early 80's late 70's 5th Avenue. Probably cost you $10
