Re: M1 w/Stage 6 heads Intake gasket question???
[Re: Jet Doc]
#441296
08/18/09 11:03 AM
08/18/09 11:03 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
These look like 3 of the .060 gaskets. Looks to be almost a 1/4 inch of gasket material.
So thats .180" or almost a 1/4" per side? Try sending a PM to member zippy and see if he can indentify that manifold part #. Sounds like the wrong manifold. Or the block/heads have been milled quite a bit. I just measured my Stage VI specific manifold from top of the port where #1 and #2 meet the head=14" Then I went to my 451 low deck with Stage VI heads and a Victor 440 intake and did the same and got 13.25". Now this is with a tape measure as best as I could do it. Adam call me if I can help, Don Are the bolt holes on the manifold enlarged a LOT?
[Re: J_BODY]
#441300
08/19/09 10:40 AM
08/19/09 10:40 AM
Posts: 250 Wisconsin
Jet Doc
Wisconsin
That's the intake I have PN-P4532758. I'd like to get a measurment of the mounting surface thickness to determine if the intake has been milled or not.
[Re: Jet Doc]
#441301
08/19/09 12:26 PM
08/19/09 12:26 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Casting P4532134 should be the head, not the intake....If it's the intake, sounds like trouble!
The intake should be casting P4532756 (packaged number P4876127).
Reducing and correcting the chamber volumes via milling on Stage VI's is very common, alot of times they are off end to end so what guys do is mill until the largest chamber was close to whatever spec they're looking for, and then grind out the remaining three to match. Or for more control, mill the whole thing even further and then make all the chambers however they want.
So if the heads were prepped much at all and ccs were changed, I'd suspect they have been milled and the intake fit wasn't accounted for until it was too late. In other words, someone cut the intake (or the intake flange on the head, but probably not, because there wouldn't be any valve cover rail left) too far and then had to use the gaskets to make up for it.
[Re: ZIPPY]
#441302
08/20/09 09:51 AM
08/20/09 09:51 AM
cudadon
New Lenox IL
Hey Zippy, the intake I have is casting # 4876128, I know it works as I have run it before I switched to low deck 451 with a Victor. Thanks, I knew you would know what the #s were! Don
