Tightening Convertor Bolts,,,,good place to anchor ?? #441187
08/17/09 06:56 PM
08/17/09 06:56 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Got the motor and trans back in,,,buttoning things up.
got the convertor in.......bolts in,,,loc tite..etc.
Dumb question................
WHERE IS A GOOD PLACE TO WEDGE SOMETHING TO KEEP THE MOTOR FROM TURNING OVER,,, so i can really tighten the convertor bolts down,,,,
didnt know if i should wedge a screwdriver or something into the ring,,convertor,,etc,,,to keep it from turning as i tighten it...dont want to mess anything up,,,etc.
WHAT DO YOU GUYS NORMALLY DO ?????
WILD Bill,,, ? lol
thanks,
Doug
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: 69CHARGERMD] #441188
08/17/09 07:07 PM
08/17/09 07:07 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
What I have done ....
Put some lock-tite on each bolt - snug-em-down and then just RAP the wrench with a rubber hammer.
They have never come loose.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: 69CHARGERMD] #441189
08/17/09 07:10 PM
08/17/09 07:10 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have some one hold the crank W/ a socket.
It's about the only time I need another pair of hands on a trans install anymore
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: 69CHARGERMD] #441190
08/17/09 07:28 PM
08/17/09 07:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If you postion the wrench and convertor at the right angle, you can get them tight without the convertor turning. Does that make sense?
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: Challenger 1] #441191
08/17/09 07:32 PM
08/17/09 07:32 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I just put the plugs in it, at 15:1 it is very hard to turn over with a wrench on the flexplate bolts. One thing I found that is a big help for me is to use a box end wrench and put a screwdriver handle between the wrench and the oil pan, in my case it's a perfect fit and stops the wrench from slipping.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: WILD BILL] #441192
08/17/09 07:32 PM
08/17/09 07:32 PM
south louisiana
lowell66dart Offline
south louisiana
Craftsman makes a swivel head 3/8 drive rachet, about a foot long. I use red Locktite and snug them all up. I then rotate the bolt to the corner under the oil filter where the block meets the pan. The rachet head is small and fits easily. You will be pushing away from the pan towards the tire. This is on a smalblock.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: 69CHARGERMD] #441193
08/17/09 08:39 PM
08/17/09 08:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I use an old craftsman 3/4 combo wrench that I ground back side flat for better bite. Works great on big blocks, as the box can turn crank enough that the werench wedges against bottom of block between pan lip and flexplate, that it won't jump off. Once tight, back the crank up to get wrench out, then grab the next one and spin crank around till it wedges again.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: buildanother] #441194
08/17/09 08:43 PM
08/17/09 08:43 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Take a large plastic handle screw driver and wedge it between the flywheel/converter and trans bell housing. It will roll a little then just tighting the crap out of it.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: lowell66dart] #441195
08/17/09 08:46 PM
08/17/09 08:46 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I use the box end of the wrench and run it up against the block skirt for the very final tightening. It will hold the wrench as you get the last few degrees of torque on the wrench.
Then I pull it back slightly to get the box off the nut.It works like a charm and saves trying to hold the crank bolt at the same time.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: The Shadow] #441196
08/17/09 08:59 PM
08/17/09 08:59 PM
KENTUCKY
KENTUCKY
Thanks guys............
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: Challenger 1] #441197
08/17/09 09:03 PM
08/17/09 09:03 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If you postion the wrench and converter at the right angle, you can get them tight without the convertor turning. Does that make sense?
It does to me, that's how we do it also, turn the engine up on compression for that vert bolt and use the wrench to put the leverage on the bolt not favoring rotating the crank
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: buildanother] #441198
08/17/09 09:32 PM
08/17/09 09:32 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
this is what i do but i paint the wrench then so i dont go grinding on another one. i have a few wrenchs painted for quick reference for certain things
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: 69CHARGERMD] #441199
08/17/09 09:47 PM
08/17/09 09:47 PM
AndyF Online content
AndyF  Online Content
Mancini Racing sells a little tool that bolts to the front damper for holding the crankshaft in place.
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: emarine01] #441200
08/17/09 10:07 PM
08/17/09 10:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Put the Leverage on the bolt not favoring rotating the crank. Thats the best way to do it. No special tools needed. mike
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: AndyF] #441201
08/17/09 10:10 PM
08/17/09 10:10 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I cut an opening in the bellhousing in front of the trans pan using a hole saw for the corners and then either a sawsall,air saw or whiz wheel.Then I can use a large prybar to hold the ring gear while I tighten the coverter bolts.I will try to get some pics
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: hemi-itis] #441202
08/17/09 10:15 PM
08/17/09 10:15 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Same here...
Re: Tightening Convertor Bolts,,,,good place to anchor ?? [Re: afxcoronet] #441203
08/17/09 11:17 PM
08/17/09 11:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just use the socket on the balancer bolt, the engine has to be rotated anyway.
