my 360 combo 1/4 mile times??? #441076
08/17/09 05:07 PM
08/17/09 05:07 PM
South Dakota
Mirada440 Offline OP
South Dakota
Ok Heres what i got to put into my 1980 cordoba over the winter
i have a 1977 360 was rebuilt not long before i got it.. it has some cast flat top type pistons in it bored .30 over pretty much complete stock bottom end....Has a set of dead stock j heads...
Cam i was thinkin a purple shaft like a .274 - .474 ???
Edlebrock performer intake with holley 750 DP
A set of el cheapo headers
electric fan and water pump drive
3,000 rpm stall
727 with manual valve body
3:91 sure grip with 28" slicks
Bout the basics of it....Whatta ya think?? 14.50s???
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441077
08/17/09 05:24 PM
08/17/09 05:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
14.5 to 14.7
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441078
08/17/09 07:52 PM
08/17/09 07:52 PM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
I have a '77 .030 360 in my 65 Coronet. It had been rebuild with KB domed pistons (don't know actual cr- have to run premium fuel), MP .280/474 cam, edelbrock RPM, 750 Holley, tti headers, FBO igniton and distributor, 727 with 1000 over stock TCI convertor, 3.55 rear on 255/60 15 T/A radials.
It ran 13.55 at 102mph spinning tires.
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441079
08/18/09 08:05 AM
08/18/09 08:05 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
14.20-14.50
Coming soon!!!!
Re: my 360 combo 1/4 mile times??? [Re: Mr.Yuck] #441080
08/18/09 10:20 AM
08/18/09 10:20 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a cam I'd probably look at a lunati voodoo 60402, maybe a comp XE268.
intake, I'd ditch the performer for an air gap or performer RPM.
I'd swagger you're going to be low 14's maybe nipping a 13.8 or 13.9l, especially with the intake change....
2017 Grand Cherokee Overland
Re: my 360 combo 1/4 mile times??? [Re: patrick] #441081
08/18/09 10:52 AM
08/18/09 10:52 AM
P
Paul_Fancsali Offline
P
For that weight go comp 268 or 270 single pattern cam run no higher then 26 26.5 tall rear slicks the 28s will cut the 3.91s Do not run the dual plane performer runs a stock intake before you use that paperwight. Get a LD340 performer RPM or Mopar intake Car will run arond 14.3-14.6 average at around 93-95 mph. By the way get the timing up to a total of at least 44-46 degree's total if the pistons are below the deck 7.5-8.5 to one comp jst the 750to 70-71- frt rear no more then 77s depending on air temp and altitude
Re: my 360 combo 1/4 mile times??? [Re: Paul_Fancsali] #441082
08/18/09 06:52 PM
08/18/09 06:52 PM
South Dakota
South Dakota
Would running a 904 Help or not?? Ive been told by a few guys the 904s are lighter and would work better and on the other hand ive been told the 904 is weak and to use the 727 ??
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441083
08/18/09 08:01 PM
08/18/09 08:01 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I ran 11.30s for 8 years with a 904
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: my 360 combo 1/4 mile times??? [Re: 69L78Nova] #441084
08/19/09 04:00 PM
08/19/09 04:00 PM
P
P
I can say that the 904 is worth close to .15 to near .2 second in the qtr.track tested yes there is that much rotating mass difference. However I will never use a 904 again behind a 360 one too many explosive failures. The present 727 is staying until it dies
Re: my 360 combo 1/4 mile times??? [Re: Paul_Fancsali] #441085
08/19/09 04:07 PM
08/19/09 04:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
IMO the little bit of gain isn't worth it. Longevity and consistancy is the name of the game for me. Being the quickest or fastest isn't what wins in bracket racing or in Pro heads up at times for that matter.
Re: my 360 combo 1/4 mile times??? [Re: Paul_Fancsali] #441086
08/19/09 06:59 PM
08/19/09 06:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
never seen a 904 explose like a 727...
been using the same 904 in a 69 barracuda since 1993 with a transbrake...been rebuilt once due to a ring gear braking and took out the overrunning clutch...
another 904 in 360 dart...working on 3rd year...
look at signature and see that they are running pretty good.
Tony
70 AARCuda Vitamin C
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441087
08/20/09 04:16 PM
08/20/09 04:16 PM
Locomotion Offline
Locomotion  Offline
Even if you know how to tune the 750 double pumper, it will not perform to expectations. You have too much weight and not enough gear, compression or converter for the carb. A 750 vacuum or a different, smaller carb should work better in the long run.
Nothing wrong with a 904 in a performance application if it's built right.
Re: my 360 combo 1/4 mile times??? [Re: Locomotion] #441088
08/20/09 07:04 PM
08/20/09 07:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With stock heads and your mild compression I'd be looking at a 650vacuum carb or a tuned thermoquad before a 750DP.
Re: my 360 combo 1/4 mile times??? [Re: DaytonaTurbo] #441089
08/22/09 04:37 PM
08/22/09 04:37 PM
South Dakota
South Dakota
I also have a 600 edlebrock on the shelf...Would that be a better carb??? Would i be better off trying to find some steper gears?? I know where i can find suregrips that have 4:10s and one with 4:30s but i wasnt sure if that steep of gear would help??
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441090
08/23/09 02:31 PM
08/23/09 02:31 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yes, the eddie will be a better fit. I had a stock long block 360, 1406 eddie, Air gap, comp XE262, MP166K converter and 3.55's, and 27" tires and my 5th ave could keep up with a stock 5.7L LX car, which means it should have been a low 14, maybe nipping the 13's car (never had it to the track)
FWIW, on that eddie, I used the stock secondary jets in the primary, stepped the cruise needles down one size, and went with .089" secondary jets to get my mixture right using a friends LM1 Wideband 02 sensor.
Re: my 360 combo 1/4 mile times??? [Re: Mirada440] #441091
08/24/09 08:37 AM
08/24/09 08:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The 72 340 swinger I had came w/ a 625 Carter, can ran a best of 14.02. I put on a 750HP and the car went 13.80. which do you think is a better carb? and you have more cubes and more cam.
Coming soon!!!!
Re: my 360 combo 1/4 mile times??? [Re: Mr.Yuck] #441092
08/24/09 09:51 AM
08/24/09 09:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The 750 DP is one of the best carbs ever made. with a 3000 stall just try it. A 600 is probably too small for all out peformance but you can try it? don't over think anything till you drive and make some runs. Big first items is make sure you have your distributor re curved with light springs right from the get go.Set total mechanical advance to 35 or 36 and don't hook up vacuum advance for a couple three weeks (if ever it's a crude cruise gas mileage device designed in a time we had way different fuels than now) If you must try the vacuum advance make sure it is on ported vacuum and not manifold it SHOULD NOT affect idle when you plug or unplug it.
Have some fun
Re: my 360 combo 1/4 mile times??? [Re: Dodgem] #441093
08/24/09 11:04 AM
08/24/09 11:04 AM
P
P
The 4.30s will work but get the tires to at least 28 inches tall. I have run 4.30s at the track but you will need a cam that will power you to at least 5800-6000. The 4.10 s maybe just right for a more dual purpose car. With 29.5 tires I drive my car now with 4.56s to tracks and back in some cases 80 miles one way
