Page 2 of 3 1 2 3
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44074
08/16/07 09:43 AM
08/16/07 09:43 AM
Andrewh Online content
Andrewh  Online Content
compaired to the mp crate, you would still build your own?
Re: Anyone use one of the "blueprint engines" crate mot [Re: Andrewh] #44075
08/16/07 10:00 AM
08/16/07 10:00 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Still interesting. The helicoil is a std repair, I wouldnt call that a bad thing. But all the incidentals that were missing, but the engine was run? Seems like they must have a shelf of "break in" parts for small block mopars? I still dont think they run it. I know the same parts that go on it to dyno, or are needed to stick it on a running stand like I have, would all have to be pulled to not be included. Why would they do that? As long as you are satisfied, they did fine by you. I dont think I would be if I were in your position, disregarding how it runs for you right now.
Re: Anyone use one of the "blueprint engines" crate mot [Re: moper] #44076
08/16/07 10:47 AM
08/16/07 10:47 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Ya, it is not a bad deal for what it is, If I built it it would be about the same price or a bit more, but it would be a much better motor...
The reason I got it was because of time... I needed a motor for the nats and this fit the bill and I could have it in and running in a few weeks..
If I did not have that constraint, I would have done something else. I would have built one, the MP motor is not that great as well, about the same as the blueprint motor except the MP one has the RT heads and a roller cam.
The best thing to do would be to start with a Magnum block and build your own stroker - that would be the best of both worlds... - you get the magnum heads and the roller setup...
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44077
08/16/07 10:50 AM
08/16/07 10:50 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
If you are stuck between the MP crate and the Blueprint, I would go with the Blueprint, there is some "slight" advantage to the MP one, but the cost is much less.
With that said you could add a roller setup for about $1000 and then you would have a roller motor...
As far as the RT heads, If I was building one I would get the Eddys over the RT heads, but that is me...
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44078
08/16/07 10:52 AM
08/16/07 10:52 AM
Thanks for the input. Guess I will work on rolling my own.
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44079
08/16/07 10:54 AM
08/16/07 10:54 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
The best deal was the "standard" 300 HP magnum motor which WAS $3000 and all new, but because they stopped putting them in trucks the raised the price and slapped the RT heads on it and made it $4500
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44080
08/16/07 11:02 AM
08/16/07 11:02 AM
dogdays Offline
dogdays  Offline
" ""Radiator: 170 (Summit 27" aluminum + friend welded brackets on)
* Headers (Dynomax ceramic coated): $300
* Exhaust
** $200 for jegs kit which did not fit at all (e body)
** $350 for Midas to screw it all up very bad and it still is not right, but it is on the car.
** ??? to get it done right...
* 360 Flywheel: 300
* Clutch: 200
* Trans Rebuild: 300
* Distributor: $40 (stock from Autozone)
* Bell housing alignment pins (3 sets): $60
* Breather asy: 15
* Recomened plugs: $40
* Plug wires:
* Cap:
* Rotor:
I don't get it.
None of this is their responsibility and you have no reason to fault anyone for your deciding to spend money on this. If you are swapping engines you always have to buy the small stuff. If you are swapping from a smaller to a bigger engine you always have to buy stuff that suits the bigger engine. that's just the way it is. Even swapping from a bone-stock 318 to a bone-stock 360 you still have things to buy.
Re: Dyno testing - It makes perfect sense to me that they would have a "kit" of parts to put on an engine to run it on the dyno. Fuel comes from the hose in the dyno area, dyno exhaust system, carb, distributor, wires etc, water pump and pullies or else fittings that mount to the engine, put it on the dyno and run it a half hour, after the breakin run 5 points or so and call it good.
Now look at the machine work that you will pay extra for in your "home rebuild"
Square decks
Align hone mains
Cylinder wall thickness test
Computer hone
Rotating assembly balanced
A lot of this stuff is a lot cheaper for them because they rebuild thousands of engines a year, and I wouldn't bet my life on everything being exactly as good as a talented machinist could do working one engine at a time. But, just trying to get a decent reground crank is turning out to be a problem in another engine build that I am putting together. The point is many of you don't have the facilities close to do the machine work, and you don't know how good your local machine work will be either.
As for the Mopar crate engines, since when did THEY become models of correctness? I don't have enough fingers and toes to count all the threads about how "Mopar crate engines are junk" and how you have to take it all apart and correct all the problems before you even dare to run it, and besides NO WARRANTY!!! Certainly not a 3-year 50,000 mile warranty.
Blueprint Engines is not related to me, I have no stock in the company and know no one involved. I should dislike them because they're from Nebraska and I live in Colorado, but even the most rabid Nebraska-hater has to admit that for the most part, people who live in that state are honest and straight. So I hate to see someone unload all sorts of peevishness on people that have what appears to be decent products and business practices.
If I get anywhere close to their facility, I will try to arrange a plant tour. Rapid Robert probably could visit them more easily.
R.
Re: Anyone use one of the "blueprint engines" crate mot [Re: dogdays] #44081
08/16/07 11:48 AM
08/16/07 11:48 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I did not say anything bad about blueprint engines, I think it is a great deal for what it is...
The person above wanted to know the "true" cost of swapping the motor so I gave him a detailed brake down of everything I had to buy for the swap. Overall I was not upset about what was included, just wanted to let him know what is included so he can make a decision. I would have expected the water pump to be included and possibly the distributor (like MP includes), but it was clearly stated they were not included (and I knew that), but this is something to consider when comparing the different options.
My decision came down to this, with the given cost and the time I had, the blueprint engines was the best choice, if time was not an issue I would have liked to build up my own motor.
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44082
08/16/07 12:32 PM
08/16/07 12:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Wow, this thread is chock full of incorrect information. Oh well, not much I can do to correct it without sounding argumentative.
Re: Anyone use one of the "blueprint engines" crate mot [Re: 6T6Cuda] #44083
08/16/07 12:37 PM
08/16/07 12:37 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'll stand with what I said, until proven otherwise. I'm basing that on my experience, and on what they provide for detail. I know enough about dyno stuff to see what everyone else that does dyno engines would leave in place after. Usually you'll get the water pump with it, plugs in it, the by pass hose, stuff like that. That's assuming the usual dyno carb, dyno distributor and wires, headers/exhaust, pulleys, and fuel from the metered line. They have to drain all fluids for shipment. I don't think I'm not taking a cheap shot. It's public domain, and I'm carefully looking at what they provide for info. Just stating what raises red flags with my semi educated eye, and what the listing of parts tells me. It's missing things that any dyno equipped shop I know of would leave in place. You dont take out spark plugs, or thermostats, or by pass hoses. You dont leave wide open holes into chambers or the crank case for shipment. It is built using parts which again, IMO, are less than adequate for the market segment it's aimed at (general performance engine buyer) but definately inexpensive. I'm a glass half empty type when it comes to internet sales. Experience has taught me that. Nothing personal. Just my opinion that aint worth much to anyone but me...lol.
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44084
08/24/07 09:30 PM
08/24/07 09:30 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Someone PM me about my opinions about the motor so here is the latest update:
Hello,
Right now the post saids it all...
No, I have not gotten it running well....
I am not sure if it is the Edelbrock 750 they recomend or the dirt in my fuel tank or some combination of both (which I did not know unitl I put a clear fuel filter on the new motor) - I would not have intentally done this...)...
I would recomend, starting with a new ignition system before trying to debug an old one... - moeny well spent...
It is difficult to get the timming curve they recomend 16* initial and 34* total - most have about 24* of mechanical - so some major recurving is needed...
Would I buy another one, not sure, I would build my own if I had time, but if that is not an option it is a decent setup;
Things I did not like:
1. Somewhat unsure tech support, they sounded good but some specific questions they could only answer what was "in the book" - you somewhat expect that with a bigger company; for example it took being on hold and two different calls for them to tell me what flywheel I need, they told me all kinds of stuff - everthing from the ballance weights come with the engine (what?? - I have a flywheel - should I weld them on??) to it is neutral, to it is externally ballance, then no one could tell me how much inballance it needed...
2. The did not tape up the holes when shipping - it was wrapped in a bag, but a big hole for the dist open was a bit worrysome.
3. They bore the block out to 0.04" - this is very close to the service limit, it could not be rebuilt again...
4. It is externally ballanced and I am not sure if it is because mine is not running well, or it is not ballanced real well... - I assumed they used lighter pistons, yet stuck with the stock LA 360 ballance...
BTW:
1. Don't forget to add tax and shipping to the total price...
2. They did not include any oil filter adaptor (you can not screw in an oil filter on the motor)
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44085
11/28/09 10:18 AM
11/28/09 10:18 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
With the season "over" and me destroying the clutch in my car, along with this engine still not running right, I decided to pull the motor...
I did a leakdown on the even cyls - all read about 20% (80% leakage at 15 psi) and were leaking out the oil pan. Engine was not hot (because I had parts taken off), so that will make a difference.
All the plugs had oil on the ends of the threads, that coupled with a PM I got from someone about the springs I decided to pull the motor and blueprint it (at least go through it and know what I got).
I have the motor torn apart and here is what I have noticed:
1. The cam appears good (yeah)...
2. The lifters were all marked with white paint to ensure they are rotating
3. They weighted and the con-rods were ground to match weight (the weight was marked on them)
4. All the rods were color coded marked
5. The block & crank was numbered (mine was 36 I think) with a sharpie
6. They drilled a LOT of metal out of the crank... - all that to externally balance the engine???
7. Noticed a slight mark along the direction of the pistons (no deeper then the hash marks) on most of the cylinders.
8. Some ware marks at the bottom of the cylinder for some of the cyls.
Going through the heads next...
More updates to follow.
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44086
11/28/09 10:28 AM
11/28/09 10:28 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
IIRC .. there was a topic about this place before .....
Read this link to their site ....
http://www.blueprintengines.com/about/index.html
So these people claim that they have build over TWENTY SEVEN engines PER DAY ...for EVERY DAY for 20 years......
IF you believe this ...I have a "BRIDGE" for you.
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44087
11/28/09 10:41 AM
11/28/09 10:41 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hi Rick,
Wow I see you pulled it apart.
Would be happy to help you check out any of it. I have all the needed tools for engine assy.
Let me know, do you need the flywheel machined? We can figure out the bobweights too if you want to check the engine balance.
Re: Anyone use one of the "blueprint engines" crate motors? [Re: Challenger 1] #44088
11/28/09 05:41 PM
11/28/09 05:41 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Hi Rick,
Gary, I might take you up on the flywheel part...
So far found nothing "that bad" which is bad I was hopping for a real bad valve guide or something...
I may replace the springs because what I understand they are not good for the lift of the cam.
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44089
11/28/09 06:04 PM
11/28/09 06:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Cool,
How's the ring seal in the cylinders, check the rings real close, make sure there not butting, stuff like that. What pistons are in it?
Re: Anyone use one of the "blueprint engines" crate motors? [Re: Challenger 1] #44090
11/28/09 06:15 PM
11/28/09 06:15 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
The rings all "look" good, I have not gone through them very carefully, I did put the #1 first seal in and measure the gap about 0.028" which is not "too" bad for a 4.040 bore.
I need to go through and blueprint the engine and go through everything.
I had KB 356 with a 4.040 dia (0.040 0ver 360, which I think is a lot).
The odd part about the pistons is the ridges/rings along the top, I would think you want this to be solid to transfer heat tot he block, but... Looks very fragile in a very high stressed area...
Re: Anyone use one of the "blueprint engines" crate motors? [Re: 6T6Cuda] #44091
11/28/09 07:53 PM
11/28/09 07:53 PM
colorado
chargermop Offline
chargermop  Offline
colorado
I "myself" have instaled 3 of these 408's and have not had any problems. Now that being said there were things that came up but that wasn't the motors fault it was me or just a mopar thing..lol If it was easy it wouldnt be fun....
Re: Anyone use one of the "blueprint engines" crate motors? [Re: chargermop] #44092
11/29/09 11:00 AM
11/29/09 11:00 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have the complete 408 with eddy heads. The one issue I have had was the dip stick missed the hole in the baffle on the kevco pan, counter weight snapped it off. I had to pulled the pan to get the broken dip stick out. I have put over 10,000 miles on it in two years. Some pretty hard miles. With about 25 1/4 mile passes. Also had to clean the mighty demon carb out three times. Best pass 12.74 at 108 mph with 3.23 rear gear. I have heard of issues with customer service. I think to do it again I would have one built to ease addressing any issue that could arise.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Anyone use one of the "blueprint engines" crate motors? [Re: FurryStump] #44093
11/30/09 09:18 AM
11/30/09 09:18 AM
NY usa
540challenger Offline
NY usa
Here is my drama i had with blue printed crate engines.
https://board.moparts.org/ubbthreads/show...t=2#Post4808386
Also on top of this. I had a value spring break while i was idlig at a light. thank god i shut it done once i heard the rocker getting loose.
i brought the heads to my machinst too take a look.
All the guides were too big "worn"
Plus the valve springs were way too weak for the cam they put in.
The problem with blue-printed crate engines is that they didn't stand by their work.
Page 2 of 3 1 2 3
