Re: rear end choice
[Re: rabid scott]
#440789
08/17/09 08:09 PM
08/17/09 08:09 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I have an 8.75 from a '69 Coronet 440 wagon under my '40. Width was fine, spring perches had to be changed for the old springs, since they are narrower. You also want to get the angle right, mine need to be redone.
Re: rear end choice
[Re: RodStRace]
#440793
08/19/09 11:35 AM
08/19/09 11:35 AM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
Something that may be a bit easier to find the local yards is a Cherokee axle. They are supposed to be good too. Make sure you bring your tape measure!
Cherokee axle also gives the option of disc brake rear with e-brake.
And although not mopar the Ford 8.8 is another option as it can be found under everything from mustangs to Explorers at various widths.
Re: rear end choice
[Re: bohmer2]
#440794
08/19/09 08:52 PM
08/19/09 08:52 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
currently putting a 8.8 out of a lincoln mark,,rear discs fits perfect in a 48 dodge
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
