rear end choice #440786
08/17/09 11:45 AM
08/17/09 11:45 AM
little rock, iowa
K
ken65 Offline OP
super street
ken65  Offline OP
super street
K
little rock, iowa
i have a 1950 plymouth business coupe. i want to update the rear end. what is the best fit for it? an a-body 8 3/4? i can't afford to spend big money on a custom fit 9 inch or dana. what has anyone else used?
Re: rear end choice [Re: ken65] #440787
08/17/09 02:57 PM
08/17/09 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure the spring centers and the overall width from drum-to-drum and compare the specs to those in the archives.
http://www.moparts.org/Tech/Archive/axle/16.html
Re: rear end choice [Re: ken65] #440788
08/17/09 07:42 PM
08/17/09 07:42 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I used a 1969 Fury III under mine....
Re: rear end choice [Re: rabid scott] #440789
08/17/09 08:09 PM
08/17/09 08:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I have an 8.75 from a '69 Coronet 440 wagon under my '40. Width was fine, spring perches had to be changed for the old springs, since they are narrower. You also want to get the angle right, mine need to be redone.
Re: rear end choice [Re: rabid scott] #440790
08/17/09 08:14 PM
08/17/09 08:14 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
I'm using an 8 1/4 out of a 79 chrysler LeBaron in my 40. I was going to use a 8 3/4 rear out of a 70 Barracuda Gran Coupe but couldn't afford what people were asking for a center section as all I have is the housing and the axles.
Re: rear end choice [Re: RodStRace] #440791
08/17/09 09:08 PM
08/17/09 09:08 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Used 68 Coronet rear end under the 36, no changes needed!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: rear end choice [Re: 36PLYM] #440792
08/18/09 09:11 PM
08/18/09 09:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Something that may be a bit easier to find the local yards is a Cherokee axle. They are supposed to be good too. Make sure you bring your tape measure!
Re: rear end choice [Re: RodStRace] #440793
08/19/09 11:35 AM
08/19/09 11:35 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Cherokee axle also gives the option of disc brake rear with e-brake.
And although not mopar the Ford 8.8 is another option as it can be found under everything from mustangs to Explorers at various widths.
Re: rear end choice [Re: bohmer2] #440794
08/19/09 08:52 PM
08/19/09 08:52 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
currently putting a 8.8 out of a lincoln mark,,rear discs fits perfect in a 48 dodge
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: rear end choice [Re: fstfish66] #440795
08/19/09 09:12 PM
08/19/09 09:12 PM
PA
W
Waynes48 Offline
Waynes48  Offline
W
PA
Using a 68 Roadrunner 8 3/4 rear in my 48 Plymouth P15. Width was pretty close...just had to relocate spring perches, and fabricate new spring plates because the axle tube diameter is larger, and the old ones would not work. Just need to figure out the proper pinion angle prior to welding the spring perches to the axle tubes.
