Re: separating exhaust
[Re: 72duster318]
#440783
08/17/09 11:52 AM
08/17/09 11:52 AM
Posts: 4,848 Memphis
HemiRick
Memphis
If the tubes are crimped its very hard to get them apart....Dont tighten the clamps so tight nest time.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#440784
08/17/09 12:20 PM
08/17/09 12:20 PM
RapidRobert
I think JC Witless has a puller that clamps onto both sections then you crank the bolts to pull each clamped section apart. Or acetylene torch(heat & twist)
[Re: RapidRobert]
#440785
08/17/09 12:27 PM
08/17/09 12:27 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I find the best way is to simply cut the pipes in a straight area and when you reinstall use a butt connecting band clamp.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
