68 Dart disc brake proportioning valve #440506
08/16/09 11:56 PM
08/16/09 11:56 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
what cars used the prop valve that will work with the 68 Kelsey-Hayes dis brake setup on a 68 Dart GTS? i have a 68 slant 6 dart in the backyard with manual drums. would that be the same valve? thanks!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 68 Dart disc brake proportioning valve [Re: GTSDart340] #440507
08/17/09 01:26 AM
08/17/09 01:26 AM
I would say most likely 67-72 A bodies w the kh discs. your 4 wheel drum 68 would only have a T splitter and not a prop valve.
Re: 68 Dart disc brake proportioning valve [Re: GTSDart340] #440508
08/17/09 01:49 AM
08/17/09 01:49 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
why not use a aftermarket adjustable..you can dial it in to you taste
Re: 68 Dart disc brake proportioning valve [Re: 340dart4spd ] #440509
08/17/09 02:12 AM
08/17/09 02:12 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The 73-76 prop/combo valve is a direct fit into the 68 for use with any factory disc brakes, including the K-H. I am not positive, but I think 68 was like 67 and used a separate valve in the rear brake line just behind the distribution block.
