anyone ever use one of these B-R/B W/P housings? #440418
08/16/09 10:51 PM
08/16/09 10:51 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Was looking at these on e-bay, wondered if anyone here has one and how well they work...
440 aluminum water pump housing
Re: anyone ever use one of these B-R/B W/P housings? [Re: 300by500] #440419
08/16/09 10:53 PM
08/16/09 10:53 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Are you meaning that one, or one like it. I've use the mopar housing... It's really just to lighten up the front end alittle.
Re: anyone ever use one of these B-R/B W/P housings? [Re: 70dusterjohn] #440420
08/16/09 10:56 PM
08/16/09 10:56 PM
300by500 Offline OP
300by500  Offline OP
I mean this one, the MP ones are at least twice the $$$$.
A little lighter than factory, and looks a little nicer. Aluminum may be a tiny bit cooler as well...
Re: anyone ever use one of these B-R/B W/P housings? [Re: 300by500] #440421
08/16/09 11:01 PM
08/16/09 11:01 PM
Deerfield, Ohio
Deerfield, Ohio
Okay then no I haven't.. But really how bad could they be..
Re: anyone ever use one of these B-R/B W/P housings? [Re: 70dusterjohn] #440422
08/16/09 11:05 PM
08/16/09 11:05 PM
300by500 Offline OP
300by500  Offline OP
Could cause pulley alignment issues if specs aren't right, could be too much/too little clearance between W/P vanes and housing, thermostat housing surface could be poorly finished and cause improper sealing, casting could be too thin/have defects and crack, bolt holes could be cross threaded... lots of things to watch for on ANY part.
Re: anyone ever use one of these B-R/B W/P housings? [Re: 300by500] #440423
08/16/09 11:15 PM
08/16/09 11:15 PM
Deerfield, Ohio
Deerfield, Ohio
All very true points... But if your that worried about it, but one that double that.. Or e-mail the seller or phone them and find out who makes them... Or stick around and I'll dig one of the four I got out for ya..
Re: anyone ever use one of these B-R/B W/P housings? [Re: 300by500] #440424
08/16/09 11:32 PM
08/16/09 11:32 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Looks identical to the 440 Source housing. I have their housing &pump on my 440 and like it a lot. No alignment or other problems. works fine... Might want to look at their combo price for the aluminum pump & housing. Pretty good deal when I got mine.
Old Geezer Racing
Re: anyone ever use one of these B-R/B W/P housings? [Re: SCATPACK 1] #440425
08/17/09 12:12 AM
08/17/09 12:12 AM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
here's the one i just put on my indy motor..great quality and fit perfect.. http://www.440source.com/wpumphousings.htm
Re: anyone ever use one of these B-R/B W/P housings? [Re: 300by500] #440426
08/17/09 01:09 AM
08/17/09 01:09 AM
those are made by Cal Auto Transpeed (CAT) essentially the same as 440 source/ Proform, etc. some people have reported issues with the quality, others have been happy with them.
