rear shackle angle #440318
08/16/09 09:48 PM
08/16/09 09:48 PM
RapidRobert Offline OP
recently acquired 65 Dart roller. PO put in the spring relocation kit(on the inside of the rails) & as is the rear shackles are pointing straight down. I believe these are SS springs also. Should I redrill & move the springs rearward to get them pointed rearward & if so how much. thank you for your time.
Re: rear shackle angle [Re: RapidRobert] #440319
08/16/09 09:52 PM
08/16/09 09:52 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
are thay longer than stock shackles?
how is the tire clearance?
a 4:00 angle would be good on the shackles to thr rear.
Re: rear shackle angle [Re: blownzoom440] #440320
08/16/09 09:55 PM
08/16/09 09:55 PM
stock shackles and I havent picked any wheels/tires yet
Re: rear shackle angle [Re: RapidRobert] #440321
08/16/09 10:00 PM
08/16/09 10:00 PM
scratchnfotraction Offline
say the frame shackle eye is 12:00
the spring eye should be in the 4:00-5:00 position
with the car at ride hieght and chassis loaded full weight
there is a pic of the angles in the mopar chassis book for referance
Re: rear shackle angle [Re: scratchnfotraction] #440322
08/16/09 10:02 PM
08/16/09 10:02 PM
Thanks guys
Re: rear shackle angle [Re: RapidRobert] #440323
08/16/09 10:47 PM
08/16/09 10:47 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Well those springs are super stiff.
I put ESPO 1" over springs in my 68 Dart, and had the same result, at the beginning.
Once the car was finally fully assembled, some gas was put in the tank, and the springs settled some, and they will, all was well.
my experience
codfish
Re: rear shackle angle [Re: codfish] #440324
08/17/09 01:19 AM
08/17/09 01:19 AM
I was wondering about that if they'd be too much for a daily driver as that was the way I got it & no eng/trans in yet
Re: rear shackle angle [Re: RapidRobert] #440325
08/17/09 07:56 AM
08/17/09 07:56 AM
if it unloaded now and they are striaght,might wait till you have the engine combo in there
might settel them down some
Re: rear shackle angle [Re: scratchnfotraction] #440326
08/17/09 09:18 AM
08/17/09 09:18 AM
if it unloaded now and they are striaght,might wait till you have the engine combo in there might settel them down some
Alright I'll leave em alone until I get something in there.
Re: rear shackle angle [Re: RapidRobert] #440327
08/17/09 11:51 AM
08/17/09 11:51 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Ride eternal, shiny and chrome
