Re: wide band o2 sensors
[Re: macmic87]
#440314
08/16/09 11:08 PM
08/16/09 11:08 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Mine is installed right after the header collector and works great.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#440315
08/16/09 11:47 PM
08/16/09 11:47 PM
Posts: 902 Bellevue, WA
Blackwidow69
Ring Knocker
Ring Knocker
Bellevue, WA
MIne is right after the collector and seems to work fine as well.
1969 Ply Roadrunner, 383 4-speed on street tires.
3,830 lbs race weight.
Best 1/4: 13.1 @ 106.83
440 & overdrive 4 speed going in.
2005 Power Wagon 35X12.5 KM2's
[Re: Blackwidow69]
#440316
08/17/09 07:44 AM
08/17/09 07:44 AM
Posts: 15,489 the boonies
aarcuda
the boonies
[Re: aarcuda]
#440317
08/17/09 08:40 AM
08/17/09 08:40 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Widebands sensors will work in any part of the exhaust assuming there are no leaks. They do not need to be close to the engine like narrow band sensors. Sticking them up the tailpipe can produce false readings unless you use a special adapter that Innovate sells.
I'd just drill into the pipe and weld a bung on.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
