96 dodge caravan tranny problems.help #440229
08/16/09 08:35 PM
08/16/09 08:35 PM
Anonymous OP
Anonymous OP
ok guys my 96 voyager devoloped trannys problems.it has been perfect up to this point.it will go into gear but will not shift.it will go untill a certain point then kick out.if you stop and shut it off it will move but not shift and then kick out.does anyone know what is up what i should look at.it is our daily car with three kids one that is disabled.please help if you can.also it does not have reverse it sounds like it goe in but it will not move.speedo works it does buck and backfire when you rev it after it kicks out.whats up thanks
Re: 96 dodge caravan tranny problems.help #440230
08/16/09 11:34 PM
08/16/09 11:34 PM
Anonymous OP
Anonymous OP
come on guys i know there has to be someone who can help.it wont move in reverse but you can here the clutches when you put it in gear please someone chime in please.
Re: 96 dodge caravan tranny problems.help #440231
08/16/09 11:46 PM
08/16/09 11:46 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
you need to link up to a computer...it could be as simple as a sensor....
Re: 96 dodge caravan tranny problems.help #440232
08/17/09 12:35 AM
08/17/09 12:35 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
when i worked for the local dealer the tranny man was a friend and i believe he said the major pobs were the solinoid shift pack, if that helps call the dealer an see if there are any tsb,s or recalls on your van.
