Width of Volare 8.25 rear? #440085
08/16/09 05:15 PM
08/16/09 05:15 PM
Scottsdale, AZ
K
kenz Online content OP
kenz  Online Content OP
K
Scottsdale, AZ
Does anyone know the drum to drum width of a Volare 8.25 rear? It's from a '79 wagon if it matters.
Thanks,
ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: Width of Volare 8.25 rear? [Re: kenz] #440086
08/16/09 07:56 PM
08/16/09 07:56 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
not shure if it matters but the track is 58.50" and the sp/pad to sp/pad is 44.46".
Re: Width of Volare 8.25 rear? [Re: moparsquid] #440087
08/16/09 10:13 PM
08/16/09 10:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: Width of Volare 8.25 rear? [Re: In_The_Pink] #440088
08/16/09 11:46 PM
08/16/09 11:46 PM
Scottsdale, AZ
K
K
Scottsdale, AZ
http://www.moparts.org/Tech/Archive/axle/17.html
I looked there but was always told that the chart there isn't correct. I was hoping someone could verify.
Thanks,
Ken
www.moparsaz.com
Re: Width of Volare 8.25 rear? [Re: moparsquid] #440089
08/16/09 11:47 PM
08/16/09 11:47 PM
Scottsdale, AZ
K
K
Scottsdale, AZ
I assume track is the same thing? If so, this sounds just a little wider than an A-body, right?
Thanks,
Ken
www.moparsaz.com
Re: Width of Volare 8.25 rear? [Re: kenz] #440090
08/16/09 11:58 PM
08/16/09 11:58 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
the a is smaller by almost 3 " (55.6) and pad to pad is 43" that equats to about little over 1 1/2 each side . you woul most likely get offset shackles or relocation kit and remount you pads anyway.
Re: Width of Volare 8.25 rear? [Re: moparsquid] #440091
08/17/09 10:33 AM
08/17/09 10:33 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
They'll fit under a Duster with stock 14" wheels, the track is about 3" wider so about 1 1/2" per side.
We didn't have any perches so we made em' out of 2X3 box tubing , used some old 8 3/4 shock plates & went to the parts house & got new U-bolts.
Had to get the car back on the road!
Butch
Re: Width of Volare 8.25 rear? [Re: CHRYCOFAN] #440092
08/17/09 11:37 AM
08/17/09 11:37 AM
Scottsdale, AZ
K
K
Scottsdale, AZ
Thanks Mopasquid & Chrycofan. I found a Volare rear with 3.21 gears and a sure grip. Looks like it might be a cheap alternative to a B-body 8 3/4 for my daughter's 318 Duster. :-)
Chrycofan, what size tires is that on the back of your car?
Thanks again for all the help.
Ken
www.moparsaz.com
Re: Width of Volare 8.25 rear? [Re: kenz] #440093
08/17/09 11:43 AM
08/17/09 11:43 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the 7 1/4" from my M was 61" drum to drum. I've heard the 8 1/4" are about 1/2" narrower. either way, they're about the same width as a '68-70 B body rear.
2017 Grand Cherokee Overland
Re: Width of Volare 8.25 rear? [Re: kenz] #440094
08/17/09 12:13 PM
08/17/09 12:13 PM
Scottsdale, AZ
K
K
Scottsdale, AZ
Are these the new perches I need?
http://www.summitracing.com/parts/DCC-4120074/
Thanks,
Ken
www.moparsaz.com
Re: Width of Volare 8.25 rear? [Re: kenz] #440095
08/17/09 03:45 PM
08/17/09 03:45 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
thats them.
Thanks,
Ken
Re: Width of Volare 8.25 rear? [Re: moparsquid] #440096
08/18/09 01:45 PM
08/18/09 01:45 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
If I remember they're 215/70/14 on the original 14X5 rims.
Just remember you need 8 3/4 shock plates & bigger u-bolts since the 7 1/4 has smaller tubes than the 8 3/4. the Driveshaft needs to be shorter too for the 8 1/4, we used the old one from the Aspen & it fit fine in the Duster.
The pads above are fine.
Just jack it up & let the axle hang & take a pinion angle reading like that...don't move the car & lay the 8 1/4 in on the perches & re-set to that angle & you're good to go.
Center it side to side also.
Butch
