spark plug wiring on 97 ram #439882
08/16/09 01:04 PM
08/16/09 01:04 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
Need some help, i fog this is the only place that can HELP me, picture out of a manual is what im looking for. thanx
Re: spark plug wiring on 97 ram [Re: zlumlord] #439883
08/16/09 01:48 PM
08/16/09 01:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
do you want the firing order or placement diagram? try
http://autorepair.about.com/cs/faqs/l/bl654h.htm
Re: spark plug wiring on 97 ram [Re: mopars4ever] #439884
08/16/09 04:13 PM
08/16/09 04:13 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
now i need a simple picture so i can rewire whole thing from scratch!!Another qusetion should i change plugs hot or cold?
Re: spark plug wiring on 97 ram [Re: zlumlord] #439885
08/16/09 04:19 PM
08/16/09 04:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
what is the problem your having?
Re: spark plug wiring on 97 ram [Re: mopars4ever] #439886
08/16/09 07:07 PM
08/16/09 07:07 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
think i have 2 wires crossed but truck runs great, you cant even tell its running so smooth. The other problem i got is on pass side 1st plug n last plug in so tight cant gett hem out tried cold,then hot cant get them the f out.I run bosch platinum plugs 4 prong only plug that works i'm taking out 2 prong plugs so the place who had the truck last switched the plugs..... I'm calling them out tommorrow!!
Re: spark plug wiring on 97 ram [Re: zlumlord] #439887
08/16/09 10:18 PM
08/16/09 10:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
if you have the wires crossed i would think that the check engine light would come. firing order 18436572, i use cheap champion plugs with no problems. 8 cylinder correct?
Re: spark plug wiring on 97 ram [Re: mopars4ever] #439888
08/16/09 11:34 PM
08/16/09 11:34 PM
scratchnfotraction Offline
pull the heat tubes off of them
then get on it with just a socket and ratchet..no extetions
use a 3/8 drive air gun on them if need be
Re: spark plug wiring on 97 ram [Re: mopars4ever] #439889
08/17/09 05:51 AM
08/17/09 05:51 AM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
yes v8 360
