Re: Electric Fuel Pump with Mech Pump
[Re: DaytonaTurbo]
#439846
08/16/09 01:38 PM
08/16/09 01:38 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Agree. As DT said above, I've heard the same admonition against using both due to the failed diaphragm safety issue.
Plus, removing the mechanical-pump slightly reduces HP loss from mechanically driving the pump.
That is how my '71 Charger is set up (electric pump / block-off plate on engine block.)
That said, I have also seen advice, including Holley & Factory "Mopar Performance" advice, to use both pumps together.
Piston Aircraft engines often use both mechanical and electric fuel pumps, in series.
[Re: D_C]
#439849
08/16/09 02:42 PM
08/16/09 02:42 PM
Posts: 615 Id
mopeman
Id
I was going to install a carter electric pump as a boost pump for the track and when the car sits a while and needs the bowls filled. I will have a switch under the dash for it.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
[Re: mopeman]
#439850
08/16/09 03:00 PM
08/16/09 03:00 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
That's what I'm going to do when ever I get around to it.
[Re: topside]
#439853
08/16/09 08:10 PM
08/16/09 08:10 PM
Posts: 12,240 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I don't want to hear the electric run all the time and I have heard that many electrics won't tolerate low flow (like idling) for very long. So I run both mech and electric, but I have a micro-switch on the carb secondaries to activate the electric at WOT and I have a switch under the dash to switch on the electric should the need arise. I have ran this way for years.
Master, again and still
