Re: FLYWHEEL R&R ON TORQUE CONVERTER???
[Re: MR_P_BODY]
#439653
08/16/09 05:01 PM
08/16/09 05:01 PM
Thanks,Mike! I feel like a slug all day today! Stayed late out at Woodward,was there from 11:00am to 10:30pm! Had a GREAT time as usual! Lots of cars,and beautiful weather,what else could one ask for? RandyB
#439654
08/17/09 10:18 AM
08/17/09 10:18 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Yes, i have had it done a few times at a company called PHD converter. 1414 industrial dearborn, 313-841-3457. Talk to Larry. They use a ring gear that has hardened teeth, so it is less likely to fail. Usually i was able to call ahead and have it done while i wait. The place isn't much to look at, but they do good work, and its usually easier / faster / cheaper then shipping it back to the manufacturer.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
#439656
08/17/09 08:32 PM
08/17/09 08:32 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I had a section of the ring gear let loose on a 9 1/2" converter about 5 yrs ago - it was only anchored with the 4 lugs that the conv bolts to the flexplate. A whole section came loose between the lugs. After cutting the remaining ring gear off, we added 4 more lugs to help brace the ring gear. Then we installed a new ring ourselves - I have access to a large enough lathe that we could trim/true the lugs and welded the new ring on. No vibration or problems since. Now, anytime that we get a conv that only has 4 lugs, we add the xtras before it gets installed. As suggested, any competent conv shop should be able to change the ring gear.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#439657
08/17/09 09:03 PM
08/17/09 09:03 PM
Thanks Guys! I've been thinking! Since I'll be pulling the converter(winter project)maybe I could send it to one of the shops like PTC,Ultimate,or Dynamic,for an increase in stall speed! Flashes to 4600 now. Maybe add a few hundred RPM??? RandyB
