Turn Signal Problem #439609
08/16/09 09:47 AM
08/16/09 09:47 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
I lost my turn signals recently, The flashers work, the brake lights work, the hazards work, I bought a new flasher, that didn't fix it, fuses are ok. What else can I look for to find the problem?
Re: Turn Signal Problem [Re: wtucker] #439610
08/16/09 11:00 AM
08/16/09 11:00 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You have two flashers under the dash. Did you check both of them? One is for the hazards the other for turn signals.
Re: Turn Signal Problem [Re: wtucker] #439611
08/16/09 11:36 AM
08/16/09 11:36 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
check the bulbs all grounds the connecter at the collum and the flasher.
Re: Turn Signal Problem [Re: moparsquid] #439612
08/16/09 01:51 PM
08/16/09 01:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
turn signal flasher carries black and red wires. Hazzard carries pink instead red.
Check at BLACK wire if you have 12 volts ( turn signal with key in RUN or ACC )
if not, fuse problem or wire. If yes, Then check with flasher plugged for power at red wire down the column ( turning switch harness ). If not flasher, or wire up to column. If yes, then could it be column switch.
Quite often the terminal is accidentally removed from plug when plugging in the flasher. Check for wire/terminal propperly inserted at plug cavity
Re: Turn Signal Problem [Re: stumpy] #439613
08/17/09 09:16 AM
08/17/09 09:16 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
I found one, where is the other and what does it look like?
Re: Turn Signal Problem [Re: wtucker] #439614
08/17/09 09:44 AM
08/17/09 09:44 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
both could look the same juts hazzards are heavy duties ones... some of them are squared ( originals hazzards were squared ) but turning flashers are usually the tipical round one.
if we are talking about a 71 and later B body ( that DOES LOOK it is at you avatar pic, unless I'm blind... too small ), turning flasher is located between ashtray and glove box. If unmolested or on the original place, is hold by a bracket attached a side of ashtray housing. but quite often you'll find it floating around.
hazzards on 71 and laters B bodies is attached to a similar bracket around steering column and brake pedal supports. If not hold by, then simply floating around.
Re: Turn Signal Problem [Re: wtucker] #439615
08/17/09 09:46 AM
08/17/09 09:46 AM
it looks identical just in a different spot under the dash. What vehicle?
Re: Turn Signal Problem [Re: RapidRobert] #439616
08/17/09 10:00 AM
08/17/09 10:00 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
73 Barracuda
Re: Turn Signal Problem [Re: wtucker] #439617
08/17/09 10:33 AM
08/17/09 10:33 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ok I don't know the location of it there BUT wiring color codes are the same and diagnosis the same.
black and pink wires arriving for hazzards flasher and black and red for turning flasher
FLASHER location could it be the same too
Re: Turn Signal Problem [Re: NachoRT74] #439618
08/17/09 11:28 AM
08/17/09 11:28 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had the same problem with my 67.. I replaced the square flashers with some I found and the signals and flasher still did not work.. Replaced those with modern round flashers and everything worked great....
