Re: Turn Signal Problem
[Re: moparsquid]
#439612
08/16/09 01:51 PM
08/16/09 01:51 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
turn signal flasher carries black and red wires. Hazzard carries pink instead red.
Check at BLACK wire if you have 12 volts ( turn signal with key in RUN or ACC )
if not, fuse problem or wire. If yes, Then check with flasher plugged for power at red wire down the column ( turning switch harness ). If not flasher, or wire up to column. If yes, then could it be column switch.
Quite often the terminal is accidentally removed from plug when plugging in the flasher. Check for wire/terminal propperly inserted at plug cavity
[Re: wtucker]
#439614
08/17/09 09:44 AM
08/17/09 09:44 AM
NachoRT74
Valencia, España
both could look the same juts hazzards are heavy duties ones... some of them are squared ( originals hazzards were squared ) but turning flashers are usually the tipical round one. if we are talking about a 71 and later B body ( that DOES LOOK it is at you avatar pic, unless I'm blind... too small ), turning flasher is located between ashtray and glove box. If unmolested or on the original place, is hold by a bracket attached a side of ashtray housing. but quite often you'll find it floating around. hazzards on 71 and laters B bodies is attached to a similar bracket around steering column and brake pedal supports. If not hold by, then simply floating around.
[Re: wtucker]
#439615
08/17/09 09:46 AM
08/17/09 09:46 AM
RapidRobert
it looks identical just in a different spot under the dash. What vehicle?
[Re: wtucker]
#439617
08/17/09 10:33 AM
08/17/09 10:33 AM
NachoRT74
Valencia, España
Ok I don't know the location of it there BUT wiring color codes are the same and diagnosis the same. black and pink wires arriving for hazzards flasher and black and red for turning flasher FLASHER location could it be the same too
