holley 3310 tuning/ adjustments? #438929
08/15/09 02:56 PM
08/15/09 02:56 PM
Ohio
jensenguy Offline OP
Ohio
I was hoping there was someone on here that could help me out roughly tuning my carb. Its a holley 3310-4, on my 440 that I just got broken-in recently. The engine runs ok, but it seems like it could be smoother, and the exhaust is making my eyes water.
Now Ive never done anything with this carb before, it was unbolted from the engine when I rebuilt it, and bolted back on to it when I was done. Im suprised its running as good as it is.
Im a complete newbie when it comes to carburetors, I know where the idle screw is and thats about it. So does anyone have any quick and easy tips to improve the mixture?
thanks a lot!
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438930
08/15/09 03:07 PM
08/15/09 03:07 PM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
Before you start with the carb, can you tell us what the initial timing (at idle) and what is the total timing?
Carb Basics: Do you have a vacuum gage?
Does the car have a tach?
Try spraying starter fluid or carb cleaner around the intake/carb base to see if there are any vacuum leaks. If the idle rpms change, fix the leaks before tuning the carb.
The above are just some basic things to check before digging into the carb adjustments. Once everything is ready, then we can help you out with the carb tuning.
Re: holley 3310 tuning/ adjustments? [Re: YO7_A66] #438931
08/15/09 03:13 PM
08/15/09 03:13 PM
Ohio
Ohio
Well Ive got the initial timing set a 10 btdc. As far as total timing goes, I really dont know, I cant really check that with just the stock timing mark tab can I? Also Im reluctant to change the timing too far from where I am, I had a ton of trouble starting the engine at first (for break-in) and Ive finally found the sweet spot that starts and runs quickly.
I do have a tach, but Ill have to do some searching for a vacuum gauge.
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438932
08/15/09 03:38 PM
08/15/09 03:38 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Holley.com has a great tech section complete with YouTube videos.
Holley Tech Service
Holley TV website
Make sure you check out the "Common Questions" and "Tech Library" topics.
There are some important "Basics" you should learn and understand and they are really not all that difficult:
* Importance of Correct Fuel-Level Adjustment
* Power-Valve Selection
* Accelerator-Pump - Lever-Adjustment, Squirter-Size, cam
* Idle Circuit Mixture & Secondary Idle Set-Screw Adjustment
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438933
08/15/09 03:52 PM
08/15/09 03:52 PM
yes dont change the timing till you find out where it is at now(for your baseline). Get a timing tape or measure/mark the dampener(.0632683" is (1) degree) so 2&1/4 would be 35.5 degrees(which'd be a nice conservative total(checked wo vac adv).
Re: holley 3310 tuning/ adjustments? [Re: RapidRobert] #438934
08/15/09 04:28 PM
08/15/09 04:28 PM
Ohio
Ohio
ok, I made a mark on my dampner as you suggested at 2 1/4". It looks like Im getting there, or very close to it at least. Probably 2500 - 3000 rpm, Im not sure I dont have a second person here right now.
So Im thinking my timing is at least close to where i need to be.
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438935
08/15/09 04:43 PM
08/15/09 04:43 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Can you find out and post jetting and PV numbers? that will help.
Re: holley 3310 tuning/ adjustments? [Re: SomeCarGuy] #438936
08/15/09 04:54 PM
08/15/09 04:54 PM
what cam? At idle how much vacuum & what idle speed, & (as mentioned) what PV & 1st (& easy to do) is to check your float levels.
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438937
08/15/09 04:55 PM
08/15/09 04:55 PM
Virginia
JimG Offline
JimG  Offline
Virginia
That's good that total timing is right.
You didn't mention the cam in the engine. If it's an aftermarket cam with more-than-stock valve overlap, you might need a lot more than 10* initial timing...like 15 to 18.
If that's the case, you might have the curb idle screw cranked too far open, exposing too much of the transition slot, causing the rich condition you describe.
Flip the carb over and take a look at the relationship between the t-slots and the throttle plates. The plates should expose enough of the t-slot that it looks like a square. Any more and it must be fixed, either by giving he engine more timing or other methods.
Re: holley 3310 tuning/ adjustments? [Re: JimG] #438938
08/15/09 05:01 PM
08/15/09 05:01 PM
this is what we've been missing. thank you Jimmy
Re: holley 3310 tuning/ adjustments? [Re: RapidRobert] #438939
08/15/09 05:08 PM
08/15/09 05:08 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Robert:
'twern't nothin'!
If that is indeed an issue on the OP's car, I'll post the pics of my distributor slots that I shortened using JB Weld...which, by the way, are still holding up just fine.
Did I ever thank you for making me paranoid that they were gonna just fall out?
Re: holley 3310 tuning/ adjustments? [Re: JimG] #438940
08/15/09 05:14 PM
08/15/09 05:14 PM
Robert: 'twern't nothin'!
(1) Jim you are too humble (2) no you never got around to taking care of that & I will add that I dissassembled one yesterday & the JB weld had crumbled so I expect you to start having problems any day now
Re: holley 3310 tuning/ adjustments? [Re: RapidRobert] #438941
08/15/09 05:14 PM
08/15/09 05:14 PM
Ohio
Ohio
Its got the Lunati Voodoo 60303 226/234 dur., .494/.513 lift. I was running the stock cam before the rebuild, and it was running pretty good with the carb setup the way it is still. I'll have to get a vacuum gauge for tomorrow, Im without one right now. Its idling around 7-800 rpm in park. Power valve, who knows, but I'd rather not take anything apart before lasting all my other options.
Ill start working on figuring out my float levels and go from there. Thanks guys!
Also should I try bumping my initial up to 15 or so and see what happens?
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438942
08/15/09 05:17 PM
08/15/09 05:17 PM
yes then slow your idle speed
Re: holley 3310 tuning/ adjustments? [Re: RapidRobert] #438943
08/15/09 05:19 PM
08/15/09 05:19 PM
Virginia
JimG Offline
JimG  Offline
Virginia
But don't hammer on it with the timing bumped up. If the engine likes the timing advanced (and I bet it does) you'll need to limit the mechanical advance to compensate.
Do you have any JB Weld?
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438944
08/15/09 05:39 PM
08/15/09 05:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Before punting..
Post back some of the specs..
Vacuum @ Idle.
The Holley is super EZ to tune but it all starts with making sure no leaks, adequate inital (12 degrees) timing, and high enough vacuum (>10 inches). Then next going inside the Holley for possible revs for the power valve, nozzles and jets. Seems like the idle speed is a little low..
But do it a step @ a time, post back and we can help you more..
Just my $0.015..
Re: holley 3310 tuning/ adjustments? [Re: JimG] #438945
08/15/09 05:47 PM
08/15/09 05:47 PM
Ohio
Ohio
Well it definitely likes 15 degrees initial. Exhaust seemed to get a little cleaner, but still not right. So from what im putting together, if I leave my initial at 15 without modifying my distributor Ill have too much total timing? Is that right?
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438946
08/15/09 05:51 PM
08/15/09 05:51 PM
Ohio
Ohio
Another thing,
I was trying to check my float levels, when I open the sights the back one is dry, but the front one has fuel running out. That means the float level on that one is too high correct? But the thing that got me, when I loosen the adjusting screw on either the front or the back, I get fuel running (almost spraying) out from under the adjusting screw. Should it do that?
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438947
08/15/09 05:52 PM
08/15/09 05:52 PM
yes you'll have to have your shop weld up the slots (there's a chart in the archives)
Re: holley 3310 tuning/ adjustments? [Re: RapidRobert] #438948
08/15/09 06:02 PM
08/15/09 06:02 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Archives, schmarkives!
Mopar Distributor Advance Slots
dist. degrees X 2 + initial= total
dist. degrees / slot size
6.............. .340
7............... .355
8............... .375
9............... .390
10.............. .405
11.5 ........... .420
12.............. .435
13.............. .445
14.............. .460
15.............. .475
16.............. .490
17.............. .505
18.............. .520
