smallblock lifter bore question #438927
08/15/09 02:50 PM
08/15/09 02:50 PM
south louisiana
lowell66dart Offline OP
south louisiana
How do you go about determining if the lifter bores were machined properly other than taking it to a machine shop that has the capability/fixtures to install bushings? I know that one of the reasons the bores are bushed is to correct geometry. Some also say that wacky bore angles are also the cause of some of the solid cam issues and is really why I want to check this. This is an NOS R block if that matters.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: smallblock lifter bore question [Re: lowell66dart] #438928
08/15/09 03:32 PM
08/15/09 03:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
As far as I know (and I'm not the brightest bulb in the pack)the only way to know for sure is to use a fixture, I have not known the smallblock's to have the issues that some of the bigblock's had.
