383 oil dipstick problem
#438834
08/15/09 12:42 PM
08/15/09 12:42 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
Is it possible to install the baffle/windage tray incorrectly in a bone stock 1970 383?
I recently had my engine builder repair an oil leak coming from a dowel pin on the timing cover. During the repair, the oil pan was removed and gasket replaced. Now the dipstick will not go all the way back in -- sticks out approx. 1". Wasn't that way when I brought it to him. He's trying to get out of having to fix it by saying it is impossible to put the baffle in backwards or upside down and that I probably have the incorrect dipstick.
Anyone been here before?
Until total honesty is on the table, we're not even talking about reality...
Re: 383 oil dipstick problem
[Re: Iceman01]
#438835
08/15/09 03:24 PM
08/15/09 03:24 PM
RapidRobert
Not sure on the Q(been on SB's for years now) but the pan will have to come off & I would for sure not do any more business with him unless a visual inspection up there tells you emphatically that it was not his (un)doing. EDIT he had to have tried to put the dipstick in & knew right then & there that he had made a mistake.
[Re: DaytonaTurbo]
#438838
08/16/09 12:26 PM
08/16/09 12:26 PM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Yeah, I'm pretty sure he hoped I wouldn't notice and that he could get away with it. But gimme a break, how could you not notice that!?!?
He also tried to say that I probably had the wrong dipstick and that it had probably always been sticking out ever since he originally rebuilt it. Luckily for me, I had photos of the engine taken immediately after the rebuild clearly showed the dipstick all the way in. So the problem had to have creeped in after he fixed the oil leak.
After I sent him the photo, he backed down and told me to bring it back this week and he would take another look. I'll do a Paul Harvey report later with "the rest of the story"...
[Re: Iceman01]
#438839
08/16/09 12:32 PM
08/16/09 12:32 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Is the motor out?If it is its a 10 minute job to take the pan off.You do know the tube wont go in just by pushing it.It is a interferebce fit.Its pretty much impossible to get the tray in wrong as the cut out fits the pickup.Rocky
Chrysler Firepower
[Re: therocks]
#438840
08/17/09 02:50 AM
08/17/09 02:50 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Okay, now I'm confused. Previous replies say it can be incorrectly installed to block the dipstick, now you're saying it can't?
[Re: Iceman01]
#438841
08/17/09 09:28 AM
08/17/09 09:28 AM
therocks
Niles , Ohio
My BB tray has the cutout for the pickup on one side.Mine cant be installed backwards.Does the tube not go all the way down or the dipstick itself?Rocky
Chrysler Firepower
