Read my spark plug [pics] #438783
08/15/09 12:19 PM
08/15/09 12:19 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
So I raced my car Wednesday night and I took a plug out to inspect today.
Any opinions on how it looks like it running based on the pics?
There is a red color on the porcelin center that I am wondering about
Re: Read my spark plug [pics] [Re: pacifica] #438784
08/15/09 12:21 PM
08/15/09 12:21 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
pic #2
Re: Read my spark plug [pics] [Re: pacifica] #438785
08/15/09 12:22 PM
08/15/09 12:22 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Last #3
Re: Read my spark plug [pics] [Re: pacifica] #438786
08/15/09 12:34 PM
08/15/09 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to look down in the porcelin to see what its
doing
Re: Read my spark plug [pics] [Re: MR_P_BODY] #438787
08/15/09 12:50 PM
08/15/09 12:50 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
doing
Mr P. The porcelin looks the same all the way down [identical from top to bottom]
The metal or ground inside looks slighty black with just a few small build up spots [very minor]
Re: Read my spark plug [pics] [Re: pacifica] #438788
08/15/09 02:29 PM
08/15/09 02:29 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'm no expert, but I'll give it a shot. Maybe it'll 'spark' a discussion featuring more experienced opinions.
The plug looks decently clean, so I'd say you're close to a good tune. The rim looks slightly fuel or oil fouled- maybe you're pushing a little oil in there at WOT, but not crazy. The tip of the strap doesn't look like it is running quite as hot as you want, but hot enough to run pretty clean. No signs of leanness or detonation.
OK, how'd I do?
radar
Re: Read my spark plug [pics] [Re: radar] #438789
08/15/09 04:14 PM
08/15/09 04:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oil, oil and more oil
Re: Read my spark plug [pics] [Re: Quicktree] #438790
08/15/09 04:17 PM
08/15/09 04:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
forget the porcelain, maybe this will help you
http://cochise.uia.net/pkelley2/sparkplugreading.html
Re: Read my spark plug [pics] [Re: Quicktree] #438791
08/15/09 04:20 PM
08/15/09 04:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hard to tell but the base ring looks wet black, if so it's oil. if it's dry black sooty it's rich
Re: Read my spark plug [pics] [Re: Quicktree] #438792
08/15/09 04:22 PM
08/15/09 04:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the red color is probably the fuel you are using but tells little about the tune..
Re: Read my spark plug [pics] [Re: Quicktree] #438793
08/15/09 04:32 PM
08/15/09 04:32 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
How much idling around have you done since the last run?
Re: Read my spark plug [pics] [Re: Quicktree] #438794
08/15/09 04:32 PM
08/15/09 04:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that is what I base my plug reading's from also, look's a little oily to me also.
Re: Read my spark plug [pics] [Re: dartman366] #438795
08/15/09 04:37 PM
08/15/09 04:37 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Another good read is here
Re: Read my spark plug [pics] [Re: pacifica] #438796
08/15/09 09:08 PM
08/15/09 09:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
If it shines after several runs there is oil in the combustion chamber Which will slow the car down compared to no oil in the chamber. I agree on the red color, probally fuel dye and being run a little rich at one time or another
Re: Read my spark plug [pics] [Re: Cab_Burge] #438797
08/15/09 09:29 PM
08/15/09 09:29 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You really need a spark plug magnifying tool to correctly read your plugs. You can't always see tiny specks of aluminum, ect with the naked eye and it's these small specks that tell tales.
Re: Read my spark plug [pics] [Re: pacifica] #438798
08/15/09 09:52 PM
08/15/09 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
here also
http://www.4secondsflat.com/Spark_plug_reading.html
this is how I've been reading my plugs for years
Re: Read my spark plug [pics] [Re: MR_P_BODY] #438799
08/15/09 10:49 PM
08/15/09 10:49 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
Ok so after reading all 3 links...the first link says ground strap shows heat range and the other 2 links say it shows timing...so which is it?
Re: Read my spark plug [pics] [Re: 11secondC] #438800
08/15/09 10:54 PM
08/15/09 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the internet... you might get some more ideas
BUT I've use the strap as a timing indicator... as
in the link I posted
Re: Read my spark plug [pics] [Re: MR_P_BODY] #438801
08/15/09 10:57 PM
08/15/09 10:57 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Thanks everybody, been gone all day, took the car on a long cruise with 2 friends just got home. Will read all the links you guys supplied. Thanks again!
Also those were not new plugs and they have been in the car for at least a year/2k miles.
Re: Read my spark plug [pics] [Re: MR_P_BODY] #438802
08/16/09 12:10 AM
08/16/09 12:10 AM
ky
68roadrunner Offline
ky
i also use the stap to check timing. on gas that is. iam getting ready to run my fist alky motor, how will this affect it?
