Read my spark plug [pics]
#438783
08/15/09 12:19 PM
08/15/09 12:19 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
So I raced my car Wednesday night and I took a plug out to inspect today.
Any opinions on how it looks like it running based on the pics?
There is a red color on the porcelin center that I am wondering about
Re: Read my spark plug [pics]
[Re: MR_P_BODY]
#438787
08/15/09 12:50 PM
08/15/09 12:50 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
You need to look down in the porcelin to see what its doing
Mr P. The porcelin looks the same all the way down [identical from top to bottom]
The metal or ground inside looks slighty black with just a few small build up spots [very minor]
[Re: pacifica]
#438788
08/15/09 02:29 PM
08/15/09 02:29 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I'm no expert, but I'll give it a shot. Maybe it'll 'spark' a discussion featuring more experienced opinions. The plug looks decently clean, so I'd say you're close to a good tune. The rim looks slightly fuel or oil fouled- maybe you're pushing a little oil in there at WOT, but not crazy. The tip of the strap doesn't look like it is running quite as hot as you want, but hot enough to run pretty clean. No signs of leanness or detonation. OK, how'd I do? radar
[Re: Quicktree]
#438790
08/15/09 04:17 PM
08/15/09 04:17 PM
Quicktree
[Re: pacifica]
#438796
08/15/09 09:08 PM
08/15/09 09:08 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
If it shines after several runs there is oil in the combustion chamber Which will slow the car down compared to no oil in the chamber. I agree on the red color, probally fuel dye and being run a little rich at one time or another
[Re: 11secondC]
#438800
08/15/09 10:54 PM
08/15/09 10:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok so after reading all 3 links...the first link says ground strap shows heat range and the other 2 links say it shows timing...so which is it?
This is the internet... you might get some more ideas BUT I've use the strap as a timing indicator... as in the link I posted
[Re: MR_P_BODY]
#438802
08/16/09 12:10 AM
08/16/09 12:10 AM
Posts: 877 ky
68roadrunner
ky
i also use the stap to check timing. on gas that is. iam getting ready to run my fist alky motor, how will this affect it?
