727 Torque Converters
#438657
08/15/09 07:54 AM
08/15/09 07:54 AM
Posts: 607 NY
old340dog
NY
I just did a rebuild on my 340 motor and am trying to decide if should replace torque converter before we put everything together. If I do would you guys recommend a stall speed converter. My motor has a com cam(XE268H) .477 lift/268duration cam. It will be used as a street car/daily driver. I have been told you need to run a tranny cooler if you install a stall speed. I figure I just need around a 2,000rpm stall speed if I went this way. Or should I just stick with a stock converter? Who would you recomend for a stall speed or stock converter? Thanks guys,
old340dog
Re: 727 Torque Converters
[Re: old340dog]
#438658
08/15/09 10:41 AM
08/15/09 10:41 AM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
I have a 2200 to 2400 stall no cooler. if you go higher you my need one. it's a different feeling, i have been a stick guy so it feels like your slipping the clutch.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#438659
08/15/09 11:11 AM
08/15/09 11:11 AM
Posts: 7,506 Az
Crizila
Az
An external cooler is always a good idea with any higher than stock stall converetor. Anything around 2500rpm will be fine for the street. You could go as high as 2900 rpm without a problem in a stock application. Obvioulsy mileage will suffer a bit, but usually not a primary concern if you want a little more zip.
Fastest 300
[Re: Crizila]
#438660
08/16/09 08:32 AM
08/16/09 08:32 AM
Posts: 607 NY
old340dog
NY
Any suggestions for good brand name stock or stall speed converters? thanks,
old340dog
