Fuel level sender-where to start?
#438437
08/15/09 12:31 AM
08/15/09 12:31 AM
Posts: 3,344 Central TX
roe
Central TX
Fuel sender doesnt read correctly on the dash. When full the needle will just bounce around from Empty to Full. When I burn off a little gas it will just sit right on E. Where do I start with trying to get this fixed before I have to pull the tank? I have a full tank so I'll have to burn off some gas before I do that. Also, new senders are either $100 bucks or $87 depending on which one you need, anything I do to my current one to fix it will be useful.
Thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Fuel level sender-where to start?
[Re: RapidRobert]
#438439
08/15/09 12:48 AM
08/15/09 12:48 AM
roe
Central TX
I'll pick up an ohm meter by the time my fluid level drops and get to work.
[Re: D_C]
#438441
08/15/09 11:08 AM
08/15/09 11:08 AM
RapidRobert
Good point on the ground. Might run a long jumper wire from the metal nipple on the sending unit all the way up directly to the battery negative post because if it's an intermittent ground problem this'd save you from going inside.
[Re: RapidRobert]
#438442
08/15/09 12:53 PM
08/15/09 12:53 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Id say it the resistor in the sender.They arent very good new and after 40 years even worse.I did the one in my 65 in Stainless 3/8 it was like 70 bucks.Its not dead on but its real close.Usually if the ground is bad its bad.I just clamp a 14 gauge wire to mine and attach it to the floor.Better than the factory strap.Rocky
Chrysler Firepower
