Notching the K-frame for Milodon pan #438301
08/14/09 10:48 PM
08/14/09 10:48 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Is it absolutely necessary to notch the K-frame to install the lo-pro 7Qt.Milodon pan into a 64 Plymouth Savoy? I'm not against cutting it but if I don't have to I would rather not spend the time cutting and filling.
Gus
64 Plymouth Savoy
Dana 60
Re: Notching the K-frame for Milodon pan [Re: fourgearsavoy] #438302
08/14/09 10:54 PM
08/14/09 10:54 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Moroso makes a 7qt. especially for those year vehicles. I believe the sump is set back a bit more and there is a notch for the drag link. Here's a drawing.
Re: Notching the K-frame for Milodon pan [Re: PC-CHARGER] #438303
08/14/09 10:58 PM
08/14/09 10:58 PM
Rittman Ohio
Rittman Ohio
Thanks but I already have one of those fabricated aluminum pans that look just like a Milodon pan.I am getting ready to install it and was just wondering.
Gus
64 Plymouth Savoy
Dana 60
Re: Notching the K-frame for Milodon pan [Re: fourgearsavoy] #438304
08/14/09 11:01 PM
08/14/09 11:01 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I have a notched k frame I can remove from my '70 cuda I will sell you. So you don't need to cut your.
Re: Notching the K-frame for Milodon pan [Re: mopacltd] #438305
08/14/09 11:22 PM
08/14/09 11:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I put the 66 up Moroso 8 qt in my 65 with no problesm.I did make a small notch on the pass side just to have a little more clearance when I had the crappy rubber OE mounts,Now that I have the polys I wouldnt have done it or worried about it.I probally had3/9 clearance before I made a tiny adjustment.Now it like 1/2 or 5 /8.You would never notice it unless I showed you it.That was 12 years ago and no problems.Rocky
Chrysler Firepower
Re: Notching the K-frame for Milodon pan [Re: mopacltd] #438306
08/14/09 11:23 PM
08/14/09 11:23 PM
That will also move the Motor down and back , later B and E body K member in a pre 1965 B body, and Stock and SS trick for better traction
Re: Notching the K-frame for Milodon pan [Re: fourgearsavoy] #438307
08/14/09 11:48 PM
08/14/09 11:48 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
i had to knotch mine about 2 inches in my 62 because im using the early flat 2 piece k-member . i think that i woulndt have to if i didnt move my motor about an inch forward to clear the firewall with the max wedge x-ram.
