A body, move rear back for tall tire #438000
08/14/09 09:02 PM
08/14/09 09:02 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
my friend has a mini tubbed Scamp with MP relocate kit on it. if you try to put a 30" tall tire on the car it will hit the quarter. if you move the front spring eye back then there is interference for the rear shackle.
my thought process was this( but i'm f'ed up) the rear needs to move back 2". i was thinking about Calverts monos with a shorter rear segment and use a front segment from a B/E body car. this will move the rear back a perfect 2" from where it is and i'm sure the rear spring could be matched up from a chevy or ford spring.
any opinions or how do you guys go about stock suspension A bodys with tall tires?
Re: A body, move rear back for tall tire [Re: sixpackgut] #438001
08/14/09 09:04 PM
08/14/09 09:04 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: A body, move rear back for tall tire [Re: BBLM23] #438002
08/14/09 09:08 PM
08/14/09 09:08 PM
Charleston
Charleston
i suggested that also and told my friend that is the better way for weight transfer but his car has new paint
Re: A body, move rear back for tall tire [Re: sixpackgut] #438003
08/14/09 09:15 PM
08/14/09 09:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
When I set my car up origionally I set the rear back 1.5" for tire clearance, when I switched to ladder bars I kept the same wheel base, my front to rear ratio is at 51% front,49% rear.
Re: A body, move rear back for tall tire [Re: dartman366] #438004
08/14/09 09:20 PM
08/14/09 09:20 PM
Charleston
Charleston
easy to do on a ladder car but on springs, did you just move the shackle back 1.5 also, seems like it would hit something back there, not sure what it is
Re: A body, move rear back for tall tire [Re: sixpackgut] #438005
08/14/09 09:26 PM
08/14/09 09:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yes moved the shackle back also.
Re: A body, move rear back for tall tire [Re: sixpackgut] #438006
08/14/09 09:52 PM
08/14/09 09:52 PM
BBLM23 Offline
BBLM23  Offline
Walter
1981 Reliant 400
Re: A body, move rear back for tall tire [Re: BBLM23] #438007
08/14/09 10:06 PM
08/14/09 10:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Where's it hit the quarter at? I even have chrome trim in my 71 dart and got a 315/60/15 in there with the 8 3/4 ...
Mopar Performance
Re: A body, move rear back for tall tire [Re: moparniac] #438008
08/14/09 10:13 PM
08/14/09 10:13 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I just did my '70 Dart. Moved the rear back 1". Boxed in a new rear spring hanger and moved the front hanger up in the frame to lower the car. A 29.5x12 Hoosier slick fits with clearence everywhere. Didnt even need to roll the wheel lip like usually do.
Re: A body, move rear back for tall tire [Re: moparniac] #438009
08/14/09 10:14 PM
08/14/09 10:14 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If you have MP spring perches welded to the rear they have three holes in them. The front hole will move the rear back about 1.5". You just have to redrill the shock mount (bottom plate) to match. Did this on our 64 Plymouth and it worked great.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: A body, move rear back for tall tire [Re: moparniac] #438010
08/14/09 10:24 PM
08/14/09 10:24 PM
BBLM23 Offline
BBLM23  Offline
28x13.5 before:
28x13.5 after:
30x13.5 after:
Walter
1981 Reliant 400
Re: A body, move rear back for tall tire [Re: BBLM23] #438011
08/14/09 10:29 PM
08/14/09 10:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Nice job, problem solved. :
Re: A body, move rear back for tall tire [Re: BBLM23] #438012
08/14/09 10:30 PM
08/14/09 10:30 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
28x13.5 before:
28x13.5 after:
30x13.5 after:
looks nice..... I hope my setup dont get all messed up since im going dana 60 / caltracs setup....
Mopar Performance
Re: A body, move rear back for tall tire [Re: moparniac] #438013
08/14/09 10:36 PM
08/14/09 10:36 PM
BBLM23 Offline
BBLM23  Offline
When I switched to Dana I got a Strange 60 from Doc Diff. We went 4 inches narrower on each side (+- a little for drum to disc change). I switched from 10" with 7.5" BS to 10" with 3.5" BS. Everything fit the same.
Walter
1981 Reliant 400
Re: A body, move rear back for tall tire [Re: Dads426] #438014
08/14/09 10:38 PM
08/14/09 10:38 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Doesn't bend the perches or anything? you weld a strap around the rear to the perches? that is a great idea.
Re: A body, move rear back for tall tire [Re: DaKuda] #438015
08/14/09 10:38 PM
08/14/09 10:38 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We did a '68 Dart for a friend - moved springs in under frame rails, moved the springs back 1 1/4", and widened the stock tubs (inside is flush with framerail. At the rear we had to notch out the braces where the bumper bolts to the rear panel to install the tubes for the spring perches. Also, the owner had originaly bought 28/11.5/15 QTP's, but when he switched to 295/65/15 MT Drag Rads (30" tall), the front still cleared the 1/4's, but the tread face is close to the rear of the tub, and has hit several times. We are now pie-slicing the tub and trimming the trunk floor/trunk extensions for tire clearance. That area is circled in pic.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: A body, move rear back for tall tire [Re: BBLM23] #438016
08/14/09 10:53 PM
08/14/09 10:53 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
awesome... hope mine works out as well I have 10" with 3 3/8 backspace convo pros
Mopar Performance
Re: A body, move rear back for tall tire [Re: rowin4] #438017
08/14/09 11:11 PM
08/14/09 11:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
wouldn't it be just as easy to change the tub?
Re: A body, move rear back for tall tire [Re: Quicktree] #438018
08/14/09 11:41 PM
08/14/09 11:41 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Not sure which post you are referring to; if mine, our options are:(1)Owner wants to stay with this size tire and ride height, and there isn't enough room at front of 1/4 to move axle forward. (2)Reshape rear of tub area. So we sliced the tub about 5" on each side and added filler metal, and trimmed about 1 1/4" across trunk floor. Pass side is done - only took about 1 1/2hr. I have to trim an electronics panel on the drivers side, which is no big deal, then modify the tub and then there will be plenty of clearance.
Re: A body, move rear back for tall tire [Re: Blown61] #438019
08/15/09 12:09 PM
08/15/09 12:09 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
The car only ran high 11's and bending the perches was not a problem. The MP perches are pretty stout; you could box them in after setting pinion angle. I questioned the practice at first, but according to 383Man, this was common practice in the 60's/70's.
