ANOTHER help my 60’ post…. *updated with more info* #437843
08/14/09 04:09 PM
08/14/09 04:09 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Ok, here’s my story as to not hi-jack the other thread….
Very similar to his story.
67 coronet, 3580 race weight (all-in).
Backhalved, pro-street 4 link (urethane-bushed rod ends), single adjustable Vari-shocks.
Dana, spool, 4.56, 32.2” tall Phoenix slick (radial) – 32-13.6-15
Launching off a brake with two-step at 4800
Shift light set at 6400 (probably shifting at 6500 or so)
Last time out went
60 ft ---- ET ---- MPH
1.440 - 10.139 - 133.37
1.458 - 10.139 - 133.54
1.477 - 10.141 - 133.54
8” converter, flashes 5800
7000 rpm through the traps (hit the rev limiter with a 7000 pill right at the traps all three runs)
Slip calcs out a little over 10%
On the engine dyno, motor made peak TQ at 5000, peak HP at 6500
1/8th mile times on the above runs were:
6.462 @ 106.47
6.470 @ 106.70
6.484 @ 106.87
So, based on where the peak HP and TQ numbers are, what kind of flash range should I be looking for to get the best 60’ times?
Re: ANOTHER help my 60’ post…. [Re: G_bob] #437844
08/14/09 04:48 PM
08/14/09 04:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
Was the track temps going way up from first to last run? The 60 ft. times varing that much and the 1/4 mile ET and MPH not changing the same or more amount has me wondering How about trying a low low gear set
Re: ANOTHER help my 60’ post…. [Re: Cab_Burge] #437845
08/14/09 05:02 PM
08/14/09 05:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If peak torque is at 5000, the convertor should be 200-300 above that, IMO.
I like to think about 1500 below shift point(flash on convertor)and 200-300 above torque peak. So in your application i would think something around 5200 flash would be optimal taking shift point and torque peak together.
5800 is too high, IMO. I bet you would see a nice gain tightening it up 600rpms or so in the 60 foot.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: ANOTHER help my 60’ post…. [Re: Cab_Burge] #437846
08/14/09 05:07 PM
08/14/09 05:07 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
I think the track temps were fairly consistent.
Time of runs were
3:06pm
3:35pm
3:57pm
One note is that this was a street legal day, so starting line conditions weren't great.
First two runs were in the left lane (which they were prepping a bit for me before my runs by putting down that powder, I'm assuming rubber, and spraying) and the last was in the right lane which they didn't prep. Also, I upped the two-step to 5000 on the last hit as well.
Don't know why the ET's could be so consistent when the 60's were so far apart.
Re: ANOTHER help my 60’ post…. [Re: G_bob] #437847
08/14/09 05:11 PM
08/14/09 05:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
One rule of thumb for the vert stall is 500 RPM over peak torque. With your 5800 rpm stall your close enough. Some cars will even et better with the stall closer to peak HP.
I feel your 60 ft. numbers are almost perfect for your ET and MPH. Perfect IMO would be 60fts. around the 1.39 1.40 range. With your 1.44 you have darn near, perfect numbers for the run IMO.
Your tune is for your ET is at 95% I say have a couple cool ones and dont worry about that last 5% mike
Re: ANOTHER help my 60’ post…. [Re: Sport440] #437848
08/14/09 06:31 PM
08/14/09 06:31 PM
gregsdart Offline
gregsdart  Offline
Each combo is different, but I am a fan of loose. I picked up about .05 going to a much looser converter, 6400+rpm compared to 5500rpm before in front of a 528 BB with peak torque at 5100 rpm. Each combo will differ, and those chasing the best ET will have more than one converter to test.
For what it is worth, a loose converter will have less hit in the first few feet, but average better to the 60 ft clocks. If you have a situation like mine, too much launch torque, then loose makes more sense. Especially if there is spin off the line, which starts the lockup process early and decreases torque output to the input shaft. If you are allready way above max torque, it only gets better with a little slippage. Check out how the ET falls off on a car with a tight converter (roughly at or below peak torque for flash) when they experience slippage at the line.
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437849
08/14/09 07:13 PM
08/14/09 07:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
1/4 mile mph seems high for ET
1/8 mile mph seems low compared to 1/4 mph, 27mph increase
Re: ANOTHER help my 60’ post…. [Re: sixpackgut] #437850
08/14/09 07:24 PM
08/14/09 07:24 PM
SoCal
Brian Hafliger Offline
SoCal
I agree! It looks like something is wrong. I would expect you engine to push your car to at least 110mph. in the 1/8...
Brian Hafliger
Re: ANOTHER help my 60’ post…. [Re: Brian Hafliger] #437851
08/14/09 09:16 PM
08/14/09 09:16 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
thats how my car acted with the sheetmetal ram on it
Re: ANOTHER help my 60’ post…. [Re: Sport440] #437852
08/14/09 09:36 PM
08/14/09 09:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd actually expect it to be quite a bit quicker, based on my own car pulling 1.459+ 60-fts. w/a much milder combination on only 275/60R15 DOT drag radials. "G" has 7 MPH more than me, but his 60-ft. times are pretty soft for the power level he's making.
Re: ANOTHER help my 60’ post…. [Re: G_bob] #437853
08/14/09 10:18 PM
08/14/09 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Last time out went
6.462 @ 106.47
6.470 @ 106.70
6.484 @ 106.87
For your MPH it should be running 10.0, I think
your stall is too high and your spending too much
time below the stall at the shift points, I believe
that is also giving you the 10% slippage(which if
you could go higher in the revs it wouldnt be that
much slippage)... your going through the traps right
at the right RPM(10% above peak HP RPM). I try to
shift AT LEAST 1500 rpm above the stall point your
shifting 700 rpm above stall.... what is you drop
in rpm's between gears
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437854
08/14/09 10:35 PM
08/14/09 10:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't think 5800 is going to hurt the 60'. it being on the rev limiter at the the end may be though.
Re: ANOTHER help my 60’ post…. [Re: MR_P_BODY] #437855
08/15/09 10:25 AM
08/15/09 10:25 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Last time out went
6.462 @ 106.47
6.470 @ 106.70
6.484 @ 106.87
thats kinda exactly what i thought... i have a hard time believing a car that is shifted 700 rpm above the convertors flash is ever going to run as good as it can. That 1500 rpm spread seems like a very good general rule to me, and i know its way closer to optimal than 700 is.
My thought is that torque is what gets a car moving(especially, like in the OP's case its an almost 3600 pound car). my guess is that the closer the convertor flashes to the cars torque peak,(optimally just a hair over) the better the car is going to launch and the better its going to accelerate at gear changes, assuming he can get the power hooked up.
I suspect this is why in this cars case the 60 foot is soft and the 1/8 mile times are as well.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: ANOTHER help my 60’ post…. [Re: B3422W5] #437856
08/15/09 05:58 PM
08/15/09 05:58 PM
gregsdart Offline
gregsdart  Offline
Does your car have tire slippage at launch?
Also, when you said 7000 rpm pill, a light went on. Sometimes those will start before 7000, costing you mph. This car sounds like it has more in it by a fair aqmount. Try at least a 7200 pill, and lower your launch rpm to 3200 for starters to see just what happens.
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437857
08/15/09 06:35 PM
08/15/09 06:35 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Here are all the numbers from those three runs.
--60-----330-----1/8-----MPH------1000-----1/4-----MPH
1.440 - 4.149 - 6.462 - 106.47 - 8.452 - 10.139 - 133.37
1.458 - 4.161 - 6.470 - 106.70 - 8.457 - 10.139 - 133.54
1.477 - 4.182 - 6.484 - 106.87 - 8.463 - 10.141 - 133.54
As a point of comparison, here are the numbers from the previous best run which was at Vegas. It was first time out and just the 5th run on the new motor. Launch and shift RPMs same as the above runs.
But, this run was prior to having the converter worked on and flash RPM was lower, "I think" more in the 5300 range.
Tires were 31-16.5 hoosier QTP's with 4.30 gears. Trap rpm was close to 7000, but it didn't hit the limiter. Slip here came out around 13-14%
1.467 - 4.190 - 6.514 - 105.61 - 8.518 - 10.218 - 132.32
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437858
08/15/09 06:47 PM
08/15/09 06:47 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
I need to get video, but so far have been alone at the track with no one to watch.
From feel, I'd day no on the first two runs and yes on the third.
Ealier in the day I had been running with the exhaust closed and launching at 4200 with 60's in the 1.50-1.53.
I definitely felt spin on those as the rear moved a little to the right on launch.
The first good run with the exhaust open (the 1.440 60), I felt the difference in the hook. Felt the front tires pick up and set down.
That was the first run with the two-step set at 4800. I made the assumption that that somehow hit the tires harder and they planted better.
My first run with the exhaust open, I screwed up and didn't set the trans brake and actually launched off idle foot braking and it spun them big time. 1.641 60'.
That's kind of what lead me to think the 4800 hit them harder and planted them better.
Re: ANOTHER help my 60’ post…. [Re: G_bob] #437859
08/15/09 07:03 PM
08/15/09 07:03 PM
gregsdart Offline
gregsdart  Offline
If you have worse spin off idle than using the brake, sounds like your suspension needs some serious loosening up. Anyone else care to comment?
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437860
08/15/09 07:39 PM
08/15/09 07:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant leave from idle either... I believe it slaps
the converter too hard and blows the tires off...
if I leave at high rpm's it hooks
Re: ANOTHER help my 60’ post…. [Re: MR_P_BODY] #437861
08/15/09 10:18 PM
08/15/09 10:18 PM
gregsdart Offline
gregsdart  Offline
My experience has been that with my car, off idle gave better traction due to time for the suspension to react. A transbrake is like dropping a clutch, shocks the suspension and might overcome too stiff of a setup. Just my opinion, because our cars are so different. More input should shed some light on this situation. How stiff are your springs? Shocks?
Re: ANOTHER help my 60’ post…. [Re: gregsdart] #437862
08/15/09 10:31 PM
08/15/09 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My springs are 90# and my QA-1s are set at 9(12 total)
with a 4-link
